We use brushless DC motors (three phase, star wound, 540 size)in RC car applications, these are controlled by electronic speed controllers (ESC's) which will obviously vary the voltage etc supplied to the motors. They use hall effect sensors on the phases. We can vary the motors timing on both the motor itself as well as in software in the ESC, we use a combination to acheive the desired power characteristics depending on track size, grip level etc. We can also set the 'drive frequency' which I believe is the PWM frequency. The available settings are 1KHz, 2KHz, 4KHz, 8KHz and 16KHz. Of those available settings, which should give more torque and which one should give higher rpm (if that's even correct)
I understand that the answer is never quite that simple, but this is the only setting I don't properly understand.. The following page gives info on the motors I use, there is a chart at the bottom and I'm interested in settings for the 4.5turn and 13.5 turn motors
