Now laptop batteries are very expensive, however I have a slightly beefy Dell Inspiron 1525 laptop with a half year old battery that works fine.
Other than complete depletion, of which I have heard ruins the life of a battery such as this, the charging will be done by the laptop itself plugged in to at least prevent over/improper charging.
Could I use this type of battery (after regulating to 9/12v if necessary) to draw maximum 100-300mA to allow for a fairly extended battery life of one of my circuits?
I'd hate to waste it, being over a hundred dollars if I recall. Information is scarce on the web and people often just rip out the battery array inside and use them, which I assume is very hard if not impossible to maintain/recharge without the original charger.
I could of course buy some rechargables and put them in to an array, however those are costly (4-12 to have enough voltage in series) and I do not even think (possibly in the future I will obtain) a "9V PP3 L-ion" battery exists, which could be helpful.
Hobbyist
  • 697
The problem, as you say, is complete depletion.
It doesn't just ruin the life of the battery. It ruins the battery.
If a Li-ion or Li-poly battery gets completely depleted it is dead. Full stop. Replace it.
If you were to use Li-ion or Li-poly batteries then you will require some kind of battery management system to shut off the power before the battery gets completely depleted.
There are dedicated ICs around to do this exact job. For example - take a look at Texas Instruments' range of Battery Monitor chips
Majenko
  • 55,955
  • 105
  • 187
  • Thank you - I never knew what kind of IC's they used for this protection. If I can find one on eBay (or similar), I will certainly consider it in the near future. I'd love to post results and use it for various low powered things. If I fail, I can always sell a "100000 year watch battery"! – Hobbyist Oct 24 '11 at 10:04
  • Ah - it even has those thermal protection circuits, makes total sense to prevent overheating and explosion in a laptop. – Hobbyist Oct 24 '11 at 10:07
  • @Hobbyist - The ICs mentioned are part of more complex protection systems intended for high volume professional use. They will **NOT** provide the protection by themselves. They need an additional IC and one to 3 extra external MOSFETS. See [figure one here](http://www.ti.com/lit/ds/slus801a/slus801a.pdf) to see what is involved :-(. See my circuit below for a cheap and simple design that does what you want. – Russell McMahon Oct 24 '11 at 11:49
USING A LAPTOP LiIon BATTERY FOR 'OTHER PURPOSES':
  • ** *WARNING ** *A Lithium Ion battery is akin to a two ended light sabre.
    In the hands of an expert it is a weapon of great power and usefulness.
    Handled wrongly it can damage the user and itself.
SUMMARY:
  • You can use the battery easily as long as Dell have not implemented a "secret" protection system (as on some systems)
  • An under voltage cutout is essential. I have provided a cheap and simple circuit below.
  • Run time would be about 40 to 12 hours at 100 to 300 mA. A cheap lead acid alarm battery may be a competitive alternative.
  • NEVER short the battery or draw above rated current. A super cheap protection means is suggested
The battery is easily able to provide the current that you want.
Using the 4400mAh version and a linear regulator will give about 40 hours at 100 mA and about 12 hours at 300 mA.
Using a switching regulator would increase run time somewhat depending on desired output voltage.
An alternative worth considering is a 12V 7AH "brick" SLA ("sealed lead acid") battery as used in many security alarm systems. These are less energy dense than LiIon but may be available at lower cost
If you use the LiIon battery you will need an under-discharge protector - these can be implemented easily and cheaply. Here is a simple and cheap example which will serve many needs. If I was doing this I may add hysteresis and maybe use an opamp but this will work well.
The TL431 acts like a precision programmable zener diode. It's output voltag is set by R1 & R2. When Vr (at R1/R2 junction) is > 2.5V (the internal reference voltage) then the TL431 conducts cathode to and and turns on Q1. When Vr falls below 2.5V Q1 is turned off. When turned on the voltage at the TL431 cathode is ~- Vref = 2.5V for the TL431 and 1.25V for the TLV431. Dimension Rb accordingly for the transistor used. C1 & C2 are 'sensible values) for the application. 100 uF would usually be fine and much less may be OK. Q1 to suit current, voltage from from battery to load etc. eg a TO92 transistor (eg BC327) would be OK at 50 mA load an 9V out. Above that level a DPak SMD or TO220 with no heatsink would be OK to a few hundred mA.
Q1 can be PNP bipolar or an N Channel MOSFET - I'd probably to use a MOSFET.
  • Current when turned off: This circuit draws Vbat/(Rsc + R1 + R2) when turned off. For the example values shown and assuming Rsc=0 then I = say 9V/37k ~= 0.25 mA. This uses 6 mAh/day or ~= 22 mAh/week. In time it too will deplete the battery but it should be OK for a week+ in th present appklication. R1/R2 could be changed to say 270k & 100k to give a drain of under 10 mAh/Month.
Rsc is provided to prevent excessive current being drawn.
For mean currents << Ibtmax then Rsc >= Vbatmax/Ibatmax.
ie shorting to ground after Rsc will not draw excessive curremt.
eg Imax = 4.4A, Vbat max = 3 x 4.2 = 13.2V.
Isc >= 13.2/4.4 = 3 ohms.
Isc will waste energy. At low current << Ibatmax the losses will be OK.
eg at 300 mA, Rsc = 3 ohms.
V_Rsc = I x R = 0.3A x 3 ohms = 0.9V.
Power in Rsc = P_Risc = I^2 x R = 0.3^2 x 3 = 0.27 Watt.
ie using a 3ohm, 1 watt series resistor will protect the battery and it will dissappear in a puff of smoke if you short circuit it to ground (Power = V^2/R = 13.2^2/3 ~~= 50 Watts.
Be CERTAIN that Rsc is the sort that will go open circuit whenover heated.
eg a cheap wire wound resistor will be fine.
You may have trouble getting the battery to deliver power, but probably not. Some manufacturers put security systems in some of their batteries so that an eg laptop must use their battery - and in the process this may make the battery hard to use elsewhere. Dell have done this on some models in the past. You will need to determine if this applies to the 1525 battery.
If you can measure between 9V and 13V on two of the battery terminals it is probably usable. Fully charged = 3 x4.2V ~= 12.6V. Fully discharged to say 3C.cell3x 3V = 9V. As long as you limit discharge to voltages above 3V and NEVER draw more than about 4A from it you should be very safe.
Replacement 1525bateries can be had in 6 cell, 4400 mAh version , for $US45, and 9 cell 6600 mAh version for $53.
Fot the 4400 mAh version (3 cells x 2 strings) the maximum current is probably 4400 mA. The manufacyurer MAY allow up to 2C = 8.8A bit 4.4A is far safer.
For the 6600 mAh version (3 cells x 3 strings) the maximum current is probably 6600 mA. The manufacturer MAY allow up to 2C = 13.2A bit 6.6 A is far safer.
As you can't be sure what capacity you are liable to have generally, limiting to > 4A is wise.
!!! E&OE YMMV DTTAH ...
The above circuit is "out of my head" and I have not tried or simulated it. It is based on the classic TL431 shunt regulator circuit. There is every reason to think it will work OK but please verify for yourself that it meets your needs OK.
Russell McMahon
  • 147,325
  • 210
  • 386
  • Most recent Dell batteries only require that the System Present pin be shorted to ground to enable output, e.g. [see here.](http://www.candlepowerforums.com/vb/showthread.php?374514-How-to-charge-a-laptop-batt-help&p=4318618&viewfull=1#post4318618) – Bill Dubuque Apr 21 '14 at 19:01
  • This will not work because R1 and R2 are across the battery, they are sure to drain the battery fully in time. I have tried an alternative to overcome this problem and it worked. I connected the top of R1 to the collector of the transistor and removed Rb1 altogether. The battery gets disconnected at the preset voltage but will not reconnect automatically when the battery is recharged. I added a LED across the load to indicate that battery is connected. And I added a push button across the transistor to momentarily short it to connect the battery again, provided it is charged. – Purushotham Racharla Nov 25 '16 at 14:09
