I am using a Xilinx 7-Series GTXE2 Transceiver configured as SATA host PHY. This transceiver is interfacing with an SATA Host controller and an SATA Gen1 device.
During initialization, I am able to see COMRESET, COMINIT and COMWAKE from host and device. They have been captured on RXDATA/TXDATA. TX/RXELECIDLE are de-asserted correctly. The host controller is able to receive and response to complete OOB sequence.
After that, the host is sending D10.2
at 1.5 Gbps to start speed negotiation. The device is responding with \$ALIGN_p\$ primitives, which are send at 1.5 Gbps.
However, from RXDATA, I can only see D27.3 D10.2 D10.2 K28.5
symbols appearing for only one clock cycle, which is 20'haaaaa, follow by 20'h5f0e4. After that, I am seeing 20'h55555, follow by 20'h5f0e4. The D27.3
and K28.5
character appeared to be correct. D10.2
appeared to be either swapped or shifted. Because the GTXE2 transceiver is unable to decode \$ALIGN_p\$, the speed negotiation failed.
I have set RXCDR_CFG
to (72'h0380008BFF40100008). The FPGA is connected to a Gen1 device.
I have implemented a control signal to release RXCDRHOLD
when I find 20'haaaaa follow by 20'h5f0e4 in the data stream. After I release the hold
signal, it becomes 20'h55555 and 20'h5f0e4. If I don't release RXCDRHOLD
, I see garbage on RXDATA
. So it seems that releasing RXCDRHOLD
only improve part of the \$ALIGN_p\$ characters. K28.5
and D27.3
was right. D10.2
is bit swapped or shifted.
I have came across another post, wherein the author may have experienced similar problems. He modified RXCDR_CFG
: Configuring a 7-Series GTXE2 transceiver for Serial-ATA (Gen1/2/3)
I was wondering, if anyone has experienced this problem with Xilinx 7-Series GTXE2 transceivers.
