I am designing a board where the datasheet suggests a power up sequence. Basically, the VDD_PLL should be turned on first, after 100us, the VAA should be turned on, followed by the internal supply and then the VDD_IO. Current I am using the AMS1117 as my voltage regulator. I know I would have to chnage this to some other power up sequencing IC if i need to meet these requirements. My question is what happens if I dont meet the power up sequence? Is it merely a safet mechanism or will the board not work. Can I ignore the specfications in the datasheet?
The chip is http://www.onsemi.com/pub_link/Collateral/AR0330CM-D.PDF
