I am using BMP180 barometric pressure sensor on an elevator for extended periods (months together), below is the guidance from Sparkfun.
Sparkfun guidance: “You should also remember that pressure changes due to weather will affect your altitude readings. The best accuracy will be obtained if you take a “fresh” p0 (baseline/reference pressure) when you need it and don’t rely on it to be accurate for extended periods due to changes in the weather”
How can I obtain a fresh p0 (baseline/reference pressure) when the elevator is continuously moving ?
