In datahseet of 74HC4046, page. 10.
Why the typical value may bigger than the max. value, or lower than the min. value? I don't think it's a typo, because there are others like this, such as p. 16
Any reason? What "typical" mean?
Those are not typos. You are not interpreting the specifications correctly. For the HIGH levels, the specification is giving the minimum value that is guaranteed to be recognized as a HIGH, e.g. 2.1 volts when Vcc = 3.0 volts. Any voltage higher than 2.1 will be recognized as a HIGH. The typical voltage, 1.7 volts, is the value that a typical device will recognize as a HIGH but it is not guaranteed. Similarly, the maximum voltage that is guaranteed to be recognized as a LOW is 0.9 volts when Vcc = 3.0 volts. Any voltage lower than 0.9 volts will be recognized as a LOW. Typically, however, a value as high as 1.2 volts will be recognized as a LOW, but again this is not guaranteed. All of the other values in the specification should be interpreted in the same way. In general, maximum and minimum values are guaranteed, typical values are not.
The first parameter is giving the lowest voltage that the chip will treat as a HIGH on its input. It is saying it will always recognise 2.0V as a high but will typically recognise down to 1.7V.
