Unlike other apple products which can be directly connected to a PC via USB, the Apple Watch is completely wireless from the point it exits the factory, as far as I am aware.
Aside from a 6-pin diagnostic port under the watches strap I am unaware of any method of connecting the device to a PC physically.
I need to be able to connect the device to a Windows PC such that I am able to make a forensically sound copy of the devices internal storage, in image format. By internal storage I mean any part of the device which stores data.
I am currently in the field of digital forensics however I have only ever worked with Windows and Linux, therefore my experience with Apple is limited.
What hardware could I use to extract the data I need from the device and/or where could I find more information on the matter?
Thank you for any input on the matter.
Although I have not received any information back from apple in regards to the hardware, through checking the device drivers that are available for the watch I have discovered further information on the types of storage that the watch uses.
Memory Types
Kris
    As somebody in the same industry I sympathise.. the answer is going to be chip-off techniques (http://www.evidencemagazine.com/index.php?option=com_content&task=view&id=922) to access the internal memory. This will not be simple or cheap. Regardless your question is probably off-topic unless you can identify the necessary chips and ask a relevant electronics design question. – David Dec 26 '15 at 20:02
  • Money isn't an issue at the moment, I'm more concerned with the how than the cost. My apologies for being off topic, I will attempt to improve the question as my understanding of the device develops. Thanks for your help :) – Kris Dec 26 '15 at 20:51
    What did Apple respond to your inquiry? – JimmyB Dec 27 '15 at 01:38
  • @HannoBinder I have yet to receive a response. – Kris Dec 27 '15 at 12:36
0 Answers0
