I've made a few things now using a RJ45 jack and a separate pulse transformer. To make the design smaller i'm looking to use a magjak or a RJ45 connector with the pulse transformer built in. The jack has the center tap pins tied together to a single pin. Does this mean that i need to tie the center pins together on the device and hook them to the single pin on the jack or is there some other connection scheme i'm not aware of? enter image description here
vini_i
  • 7,048
  • 32
  • 49
Connect the CT pin to the system power (e.g. 3V3) and place a 100nF cap as close to the CT pin as you can. Here's a sample design.
MagJack Connection
On a different connector, you may find two CT pins, so you'll need to use one cap for each pin.
Armandas
  • 7,845
  • 32
  • 56
  • What about the center tap pins on the device, what do i do with them? – vini_i Dec 19 '15 at 22:05
  • In my experience, these pins are not normally connected to the PHY. What device are you using? – Armandas Dec 19 '15 at 22:08
  • @vini_i, I've just looked at a few reference designs and not a single one has CT pins connected to the PHY. – Armandas Dec 19 '15 at 22:14
  • I'm connecting the jack to a Lantronix match port b/g. It has TX+, TX-, TXCT, RX+, RX-, RXCT pins. It is the TXCT and RXCT pins i'm not sure what to do with. – vini_i Dec 19 '15 at 22:17
    In that case, I'd recommend that you either find a connector with both of those pins broken out, or contact Lantronix and ask them what to do. I've no experience with this particular module and the documentation does not say much about those pins. – Armandas Dec 19 '15 at 22:28
  • @vini_i Alternatively, open the module up and see where the signals go. It could be a good learning experience! – Armandas Dec 19 '15 at 22:31
  • Could you add you suggestion to find a mag jack that has both pins broken out as an answer? – vini_i Jan 09 '16 at 00:55
  • @vini_i Just posted. – Armandas Jan 09 '16 at 10:17
Now that it has become clear that you are using a Lantronix module, as opposed to a PHY chip, the easiest solution is to find a MagJack that has both CT pins broken out, for example: ARJC02-111008B (just one of the cheaper connectors on Digikey).
I also mentioned in the comments that you could contact Lantronix support or see where those lines are connected on the module. While this will not help you to get the job done quicker, it may give you some good experience for your future projects.
Armandas
  • 7,845
  • 32
  • 56
The common mode level for the differential TX/RX pairs may be different on some phy's. I would not risk such an issue and find another ethernet jack with separate CT pins, so you can support separate common mode levels for TX and RX.
You could also contact Lantronix and ask if you can connect 1 CT to both TXCT and RXCT. However, you may find that they will tell you the same conclusion. After all, they broke out the pins separately, presumably so they can swap phy's on their modules while staying compatible with client's hardware.
Hans
  • 7,238
