I'm trying to get a simple UART receiver working and am close but I'm receiving slightly off values (some bits are shifted a couple places from where they should be).
Based on this answer I tried running RX through a flip flop (not sure I did that correctly) and oversampled RX. My target baud rate is 2500000, so that's 400ns per baud and 20 samples per baud (FPGA clock is 50 MHz).
Can anyone see what I'm doing wrong? Am I putting RX in the flip flop and oversampling correctly?
entity uart is port(
clk_50 : in std_logic;
reset : in std_logic;
tx : out std_logic;
rx : in std_logic;
data_in : out std_logic_vector(7 downto 0); -- data being received
data_out : in std_logic_vector(7 downto 0); -- data being sent
leds : out std_logic_vector(7 downto 0));
end uart;
architecture behavioral of uart is
signal sample_counter : unsigned(7 downto 0);
signal data_count : unsigned(3 downto 0);
type uart_state_t is (IDLE, START, DATA, STOP, STALL);
signal uart_state: uart_state_t;
signal next_uart_state: uart_state_t;
signal rx_data : std_logic_vector(7 downto 0);
signal rx_d : std_logic;
begin
process(clk_50, reset)
begin
if (reset = '1') then
uart_state <= START;
data_count <= (others => '0');
sample_counter <= (others => '1');
leds <= (others => '0');
rx_data <= (others => '0');
elsif (rising_edge(clk_50)) then
uart_state <= next_uart_state;
rx_d <= rx;
if (next_uart_state = START) then
data_count <= (others => '1');
if (sample_counter = x"ff") then
if (rx_d = '0') then
sample_counter <= sample_counter + 1;
end if;
elsif (sample_counter = x"31") then -- 20 samples per baud
else
end if;
end if;
elsif (next_uart_state = DATA) then
if (sample_counter = x"0a") then -- check rx at sample 10
rx_data(to_integer(data_count)) <= rx_d;
leds(to_integer(data_count)) <= rx_d;
elsif (sample_counter = x"13") then
data_count <= data_count + 1;
else
end if;
elsif (next_uart_state = STOP) then
data_in <= rx_data;
else
end if;
end if;
end if;
end process;
process(uart_state, reset, data_count, sample_counter)
begin
next_uart_state <= START;
end if;
case uart_state is
when START =>
next_uart_state <= DATA;
else
end if;
when DATA =>
if (data_count = x"8" and sample_counter = x"13") then
next_uart_state <= STOP;
else
end if;
when STOP =>
else
end if;
when others =>
end case;
end process;
end behavioral;
e: I think I got it - I reduced the baud rate to 1000000 and changed the logic for the START state.
