I use an Arduino Uno and already set it up to work with interrupts on digital pins 2, 3, 4 and 5 according to an explanation1 I found.
void setup() contains the following code to setup the interrupts.
  //Endable Interrupts for PCIE2 Arduino Pins (D0-7)
  PCICR |= (1<<PCIE2);
  //Setup pins 2,3,4,5
  PCMSK2 |= (1<<PCINT18);
  PCMSK2 |= (1<<PCINT19);
  PCMSK2 |= (1<<PCINT20);
  PCMSK2 |= (1<<PCINT21);
  //Trigger Interrupt on rising edge
  MCUCR = (1<<ISC01) | (1<<ISC01);
And now, the ISR( PCINT2_vect ) function is triggered on every interrupt. That works like a charm. My question is, what is the best/fastest way to find out, which pin was triggered?
I found something in Re: Is better to use ISR(PCINT2_vect) or attachInterrupt on pins 2, 3?, but I do not understand the code and it does not work out of the box. But it looks impressive...
What is the solution?
[2] http://arduino.cc/forum/index.php/topic,72496.15.html#lastPost
Edit:
At the moment, I am reading the pin state from the from the input pin register:
  if (PIND & 0b00000100)
    Serial.println( "PIN 2" );
  if (PIND & 0b00001000)
    Serial.println( "PIN 3" );
  if (PIND & 0b00010000)
    Serial.println( "PIN 4" );
  if (PIND & 0b00100000)
    Serial.println( "PIN 5" );
In the end, I want to count the interrupts on the pins. But how can I assure, that there are no counted twice?
madc
  • 251
  • At electronics, more people have probably messed around with Arduinos and other electronic things. – Earlz Sep 28 '11 at 15:18
  • If you think, the question should be over there, flag it. I solved my login problems. – madc Sep 28 '11 at 15:24
    @Earlz: This is a programming question, so **it's on-topic**. The fact that it's for a hobbyist platform is irrelevant; see the [hundreds of other arduino questions on stackoverflow](http://stackoverflow.com/questions/tagged/arduino) for reference. – BlueRaja - Danny Pflughoeft Sep 30 '11 at 23:13
I have a first solution myself, but i could not test the reliability as the hardware is not finished jet.
First I added oldPins and tickCount as global variables:
static byte oldPins = 0;
volatile unsigned int tickCount[4] = { 0, 0, 0, 0 };
And thats how I solved the ISR at the moment. Better solutions are more than welcome.
ISR( PCINT2_vect ) {
  //Read values from digital pins 2 to 7
  const byte actPins = PIND;
  //Match this values agaist the oldPins bitmask (XOR and AND for raising edge)
  const byte setPins = (oldPins ^ actPins) & actPins;
  if (setPins & 0b00000100)
    tickCount[0]++;
  if (setPins & 0b00001000)
    tickCount[1]++;
  if (setPins & 0b00010000)
    tickCount[2]++;
  if (setPins & 0b00100000)
    tickCount[3]++;
  oldPins = actPins;
madc
  • 251
    If you are updating tickCount[] in an ISR, you should be declaring it with the 'volatile' type qualifier. – bdutta74 Dec 22 '11 at 06:52
  • I updated the code inside the answer. For more information see the arduino documentation: http://www.arduino.cc/en/Reference/Volatile – madc Dec 23 '11 at 16:27
