While taking apart a 2009 Apple Time Capsule, I found a 2N3904 NPN transistor on a 2-wire cable with the emitter connected to one wire and the base and collector connected together and to the other wire. The transistor was physically attached to the back of the hard drive with Kapton tape. What is the transistor being used for?
3871968
  • 879
I am 99% sure it is a temperature sensor.
App Note AN12.14 from Microchip can tell you a little bit about it.
(This is a pretty common cheap way to measure temperature on a circuit board)
Daniel
  • 6,168
