I would like to use a FIFO in VHDL, I used coregen to make it but when I want to use it into my project, I get this error :
ERROR:NgdBuild:604 - logical block 'U101' with type 'fifo_generator_v9_3' could not be resolved. A pin name misspelling can cause this, a missing edif or ngc file, case mismatch between the block name and the edif or ngc file name, or the misspelling of a type name. Symbol 'fifo_generator_v9_3' is not supported in target 'spartan3a'.
I can't find where this error come from... Here's some parts of my code (those with the FIFO) :
component fifo_generator_v9_3 is
PORT (
M_CLK : IN STD_LOGIC;
rst : IN STD_LOGIC;
din : IN STD_LOGIC_VECTOR(17 DOWNTO 0);
wr_en : IN STD_LOGIC;
rd_en : IN STD_LOGIC;
dout : OUT STD_LOGIC_VECTOR(17 DOWNTO 0);
full : OUT STD_LOGIC;
empty : OUT STD_LOGIC
end component;
signal WRITE_EN, READ_EN, FIFO_FULL, FIFO_EMPTY : STD_LOGIC;
signal DATA_IN, DATA_OUT : STD_LOGIC_VECTOR(17 downto 0);
U101:fifo_generator_v9_3
port map (
M_CLK,
rst,
DATA_IN,
WRITE_EN,
READ_EN,
DATA_OUT,
FIFO_FULL,
FIFO_EMPTY
Q : Can someone tell me where that error come from (in my case) ? Is it possible that I'm missing a file? In that case, where can I find it?
Thanks in advance !
