i have a profinet device and an Ethernet port which is dedicated for KNX protocol. can i connect my profinet device to this Ethernet port?
Asked
Active
Viewed 288 times
Sure you can connect them at Ethernet level, but the KNX device won't start talking profinet. Are you trying to use it like an Ethernet switch or something like that? – Fizz Nov 10 '15 at 16:39
From my knowledge the KNX physical layer is not ethernet, while the profinet has the same layer as ethernet, so that ethernet port is a profinet port and you connect a PLC or profinet master. – Marko Buršič Nov 10 '15 at 18:26
@MarkoBuršič: I think he is talking about KNXnet/IP. – Fizz Nov 11 '15 at 05:07
