I solder about once or twice a week, and I use leaded, rosin-core solder from RadioShack(bought it before they went under). I do notice that their are flux fumes rising from the board when I solder something on, and I am aware that they can cause some short-term and long-term health effects determined by the frequency of inhalation.
My Question: Is a simple fan enough to blow the fumes away from my nose or should I invest money in a soldering fume extractor?
Enthurzan
  • 321
  • It need not be a big investment. [Here](https://electronics.stackexchange.com/q/541493) is one I 3D printed- it works well with a filter installed and cost little more than a cup of coffee. You can find similar projects on Thingiverse. – Spehro Pefhany Oct 19 '21 at 17:51
The fan will blow the fumes away , but where to? .Open window is good but otherwise the Volatile organic compounds Adsorb into fabrics only to be released later when the sun comes out .Fume extraction is of course best.
Autistic
  • 14,235
  • 65
Go with a fume extractor. A fan will just blow around the fumes, but they are still in the air and you can still breathe them in. The fume extractor sucks the smoke and fumes in while you are soldering and runs it through a filter, removing the fumes and harmful chemicals from the air itself. Since there are so many health concerns with inhaling fumes and smoke from soldering, it really is in your best interest to invest in a fume extractor or smoke absorber of some sort. I searched and found some very affordable smoke absorbers and fume extractors here that start at $60 or so. Not bad when you think of how much it is helping your health.
user43254
I think a fan is enough. If you're soldering at a reasonable temperature, the lead should not be vaporizing, so the smoke is mostly rosin vapor. It's my opinion that once the smoke cools down it will precipitate, thus it will not linger in the air. I am an EE, not a chemist though so make of that what you will.
I use a fan if I'm going to be soldering a lot, nothing otherwise. I do try to avoid inhaling the fumes or getting them in my eyes. I run a hepa/carbon filter in my office.
I also use lead free solder exclusively, but not because of the vapor.
Drew
  • 6,370
