Am I correct that to disable the reset pin of Attiny85, and use it as an IO pin, I need to disable the reset fuse bit(RSTDSBL)?
If so, should my RSTDSBL bit be 1 (assuming 1 = yes, disable)?
I am a little confused, because it looks like my reset pin got disabled only after I set the RSTDSBL bit to 0 (which is reverse of the logic I expected).
Adam Lee
  • 973
    Please not that after programming the fuse you CAN NOT use an in-circuit programmer any more. – Vorac Nov 09 '15 at 13:27
AVR fuses use negative logic; 1 means the fuse is unprogrammed/unset, while 0 means it's programmed/set. Thus, if the documentation says to program RSTDISBL, that means you should set it to 0.
Nick Johnson
  • 7,739
  • 44
  • Thanks for the response. Now it makes all sense and can go to bed! (I wilt accept it as the answer in 8 min; apparently I can't accept it so soon). – Adam Lee Nov 09 '15 at 11:43
