I have a peculiar problem with STM32F303 DMA.
I am using libopencm3, but I hope you'll clearly see what is happening - it's all just functions to set the control registers.
I am sending data from a const array to a DAC - but it is sending the data wrong.
(note: I have replaced the sine table contents with a 0-4095 scale for debugging)
const uint16_t sine_table[SINE_TABLE_LEN] = {
0, 16, 32, 48, 64, 80, 96, 112, 128, 144, 160, 176, 192, 208, 224, 240, 256, 272, 288, 304, 320, 336, 352, 368, 384, 400, 416, 432, 448, 464, 480, 496, 512, 528, 544, 560, 576, 592, 608, 624, 640, 656, 672, 688, 704, 720, 736, 752, 768, 784, 800, 816, 832, 848, 864, 880, 896, 912, 928, 944, 960, 976, 992, 1008, 1024, 1040, 1056, 1072, 1088, 1104, 1120, 1136, 1152, 1168, 1184, 1200, 1216, 1232, 1248, 1264, 1280, 1296, 1312, 1328, 1344, 1360, 1376, 1392, 1408, 1424, 1440, 1456, 1472, 1488, 1504, 1520, 1536, 1552, 1568, 1584, 1600, 1616, 1632, 1648, 1664, 1680, 1696, 1712, 1728, 1744, 1760, 1776, 1792, 1808, 1824, 1840, 1856, 1872, 1888, 1904, 1920, 1936, 1952, 1968, 1984, 2000, 2016, 2032, 2048, 2063, 2079, 2095, 2111, 2127, 2143, 2159, 2175, 2191, 2207, 2223, 2239, 2255, 2271, 2287, 2303, 2319, 2335, 2351, 2367, 2383, 2399, 2415, 2431, 2447, 2463, 2479, 2495, 2511, 2527, 2543, 2559, 2575, 2591, 2607, 2623, 2639, 2655, 2671, 2687, 2703, 2719, 2735, 2751, 2767, 2783, 2799, 2815, 2831, 2847, 2863, 2879, 2895, 2911, 2927, 2943, 2959, 2975, 2991, 3007, 3023, 3039, 3055, 3071, 3087, 3103, 3119, 3135, 3151, 3167, 3183, 3199, 3215, 3231, 3247, 3263, 3279, 3295, 3311, 3327, 3343, 3359, 3375, 3391, 3407, 3423, 3439, 3455, 3471, 3487, 3503, 3519, 3535, 3551, 3567, 3583, 3599, 3615, 3631, 3647, 3663, 3679, 3695, 3711, 3727, 3743, 3759, 3775, 3791, 3807, 3823, 3839, 3855, 3871, 3887, 3903, 3919, 3935, 3951, 3967, 3983, 3999, 4015, 4031, 4047, 4063, 4079
void send_dac_sine()
const uint32_t dma = DMA2;
const uint32_t ch = DMA_CHANNEL3;
dac_set_waveform_generation(DAC_CR_WAVE1_DIS);
dac_dma_disable(CHANNEL_1);
dma_disable_channel(dma, ch);
dma_channel_reset(dma, ch);
dma_enable_circular_mode(dma, ch);
dma_set_peripheral_address(dma, ch, (uint32_t) &DAC_DHR12R1);
dma_set_memory_address(dma, ch, (uint32_t) &sine_table);
dma_set_memory_size(dma, ch, DMA_CCR_MSIZE_16BIT);
dma_set_peripheral_size(dma, ch, DMA_CCR_MSIZE_16BIT);
dma_set_read_from_memory(dma, ch);
dma_set_number_of_data(dma, ch, SINE_TABLE_LEN);
dma_set_priority(dma, ch, DMA_CCR_PL_VERY_HIGH);
dma_enable_memory_increment_mode(dma, ch);
dma_disable_peripheral_increment_mode(dma, ch);
dac_dma_enable(CHANNEL_1);
dma_enable_channel(dma, ch);
First I tried to measure the output with a ADC, but then I realized I can read the DAC input register and send THAT over UART.
It is sending 8x first 16 numbers, than 8x last 16 numbers.
I have managed to capture more-or-less what's going on (dumping some registers and DAC output (first column) over USART:
Starting sine DMA
DMA started...
20, DAC = 0 CNTDR 255
30, DAC = 16 CNTDR 254
20, DAC = 32 CNTDR 253
56, DAC = 48 CNTDR 252
33, DAC = 64 CNTDR 251
35, DAC = 80 CNTDR 250
35, DAC = 96 CNTDR 249
58, DAC = 112 CNTDR 248
45, DAC = 128 CNTDR 247
63, DAC = 144 CNTDR 246
83, DAC = 160 CNTDR 245
133, DAC = 176 CNTDR 244
123, DAC = 192 CNTDR 243
129, DAC = 208 CNTDR 242
146, DAC = 224 CNTDR 241
160, DAC = 240 CNTDR 240
183, DAC = 0 CNTDR 239
16, DAC = 16 CNTDR 238
30, DAC = 32 CNTDR 237
51, DAC = 48 CNTDR 236
49, DAC = 64 CNTDR 235
26, DAC = 80 CNTDR 234
29, DAC = 96 CNTDR 233
40, DAC = 112 CNTDR 232
61, DAC = 128 CNTDR 231
100, DAC = 144 CNTDR 230
99, DAC = 160 CNTDR 229
96, DAC = 176 CNTDR 228
139, DAC = 192 CNTDR 227
131, DAC = 208 CNTDR 226
150, DAC = 224 CNTDR 225
203, DAC = 240 CNTDR 224
177, DAC = 0 CNTDR 223
20, DAC = 16 CNTDR 222
23, DAC = 32 CNTDR 221
20, DAC = 48 CNTDR 220
33, DAC = 64 CNTDR 219
28, DAC = 80 CNTDR 218
67, DAC = 96 CNTDR 217
40, DAC = 112 CNTDR 216
46, DAC = 128 CNTDR 215
77, DAC = 144 CNTDR 214
91, DAC = 160 CNTDR 213
96, DAC = 176 CNTDR 212
113, DAC = 192 CNTDR 211
134, DAC = 208 CNTDR 210
158, DAC = 224 CNTDR 209
164, DAC = 240 CNTDR 208
176, DAC = 0 CNTDR 207
20, DAC = 16 CNTDR 206
21, DAC = 32 CNTDR 205
56, DAC = 48 CNTDR 204
29, DAC = 64 CNTDR 203
66, DAC = 80 CNTDR 202
63, DAC = 96 CNTDR 201
49, DAC = 112 CNTDR 200
55, DAC = 128 CNTDR 199
68, DAC = 144 CNTDR 198
79, DAC = 160 CNTDR 197
99, DAC = 176 CNTDR 196
115, DAC = 192 CNTDR 195
168, DAC = 208 CNTDR 194
164, DAC = 224 CNTDR 193
166, DAC = 240 CNTDR 192
206, DAC = 0 CNTDR 191
24, DAC = 16 CNTDR 190
66, DAC = 32 CNTDR 189
59, DAC = 48 CNTDR 188
47, DAC = 64 CNTDR 187
39, DAC = 80 CNTDR 186
29, DAC = 96 CNTDR 185
37, DAC = 112 CNTDR 184
61, DAC = 128 CNTDR 183
66, DAC = 144 CNTDR 182
84, DAC = 160 CNTDR 181
101, DAC = 176 CNTDR 180
152, DAC = 192 CNTDR 179
133, DAC = 208 CNTDR 178
182, DAC = 224 CNTDR 177
165, DAC = 240 CNTDR 176
185, DAC = 0 CNTDR 175
33, DAC = 16 CNTDR 174
27, DAC = 32 CNTDR 173
25, DAC = 48 CNTDR 172
24, DAC = 64 CNTDR 171
41, DAC = 80 CNTDR 170
64, DAC = 96 CNTDR 169
55, DAC = 112 CNTDR 168
47, DAC = 128 CNTDR 167
66, DAC = 144 CNTDR 166
83, DAC = 160 CNTDR 165
121, DAC = 176 CNTDR 164
115, DAC = 192 CNTDR 163
154, DAC = 208 CNTDR 162
185, DAC = 224 CNTDR 161
187, DAC = 240 CNTDR 160
187, DAC = 0 CNTDR 159
55, DAC = 16 CNTDR 158
58, DAC = 32 CNTDR 157
24, DAC = 48 CNTDR 156
25, DAC = 64 CNTDR 155
35, DAC = 80 CNTDR 154
33, DAC = 96 CNTDR 153
49, DAC = 112 CNTDR 152
53, DAC = 128 CNTDR 151
87, DAC = 144 CNTDR 150
79, DAC = 160 CNTDR 149
103, DAC = 176 CNTDR 148
121, DAC = 192 CNTDR 147
133, DAC = 208 CNTDR 146
163, DAC = 224 CNTDR 145
168, DAC = 240 CNTDR 144
194, DAC = 0 CNTDR 143
34, DAC = 16 CNTDR 142
34, DAC = 32 CNTDR 141
18, DAC = 48 CNTDR 140
27, DAC = 64 CNTDR 139
48, DAC = 80 CNTDR 138
68, DAC = 96 CNTDR 137
80, DAC = 112 CNTDR 136
46, DAC = 128 CNTDR 135
63, DAC = 144 CNTDR 134
82, DAC = 160 CNTDR 133
101, DAC = 176 CNTDR 132
144, DAC = 192 CNTDR 131
166, DAC = 208 CNTDR 130
149, DAC = 224 CNTDR 129
189, DAC = 240 CNTDR 128
207, DAC = 0 CNTDR 127
23, DAC = 3855 CNTDR 126
3527, DAC = 3871 CNTDR 125
3531, DAC = 3887 CNTDR 124
3523, DAC = 3903 CNTDR 123
3550, DAC = 3919 CNTDR 122
3524, DAC = 3935 CNTDR 121
3522, DAC = 3951 CNTDR 120
3537, DAC = 3967 CNTDR 119
3525, DAC = 3983 CNTDR 118
3521, DAC = 3999 CNTDR 117
3526, DAC = 4015 CNTDR 116
3528, DAC = 4031 CNTDR 115
3523, DAC = 4047 CNTDR 114
3522, DAC = 4063 CNTDR 113
3525, DAC = 4079 CNTDR 112
3526, DAC = 4095 CNTDR 111
32, DAC = 3855 CNTDR 110
3517, DAC = 3871 CNTDR 109
3525, DAC = 3887 CNTDR 108
3527, DAC = 3903 CNTDR 107
3523, DAC = 3919 CNTDR 106
3553, DAC = 3935 CNTDR 105
3523, DAC = 3951 CNTDR 104
3522, DAC = 3967 CNTDR 103
3524, DAC = 3983 CNTDR 102
3524, DAC = 3999 CNTDR 101
3541, DAC = 4015 CNTDR 100
3520, DAC = 4031 CNTDR 99
3519, DAC = 4047 CNTDR 98
3521, DAC = 4063 CNTDR 97
3539, DAC = 4079 CNTDR 96
3517, DAC = 4095 CNTDR 95
43, DAC = 3855 CNTDR 94
3547, DAC = 3871 CNTDR 93
3519, DAC = 3887 CNTDR 92
3518, DAC = 3903 CNTDR 91
3519, DAC = 3919 CNTDR 90
3521, DAC = 3935 CNTDR 89
3530, DAC = 3951 CNTDR 88
3541, DAC = 3967 CNTDR 87
3519, DAC = 3983 CNTDR 86
3538, DAC = 3999 CNTDR 85
3538, DAC = 4015 CNTDR 84
3520, DAC = 4031 CNTDR 83
3535, DAC = 4047 CNTDR 82
3521, DAC = 4063 CNTDR 81
3523, DAC = 4079 CNTDR 80
3517, DAC = 4095 CNTDR 79
21, DAC = 3855 CNTDR 78
3542, DAC = 3871 CNTDR 77
3523, DAC = 3887 CNTDR 76
3524, DAC = 3903 CNTDR 75
3517, DAC = 3919 CNTDR 74
3517, DAC = 3935 CNTDR 73
3527, DAC = 3951 CNTDR 72
3526, DAC = 3967 CNTDR 71
3523, DAC = 3983 CNTDR 70
3523, DAC = 3999 CNTDR 69
3529, DAC = 4015 CNTDR 68
3551, DAC = 4031 CNTDR 67
3525, DAC = 4047 CNTDR 66
3542, DAC = 4063 CNTDR 65
3545, DAC = 4079 CNTDR 64
3522, DAC = 4095 CNTDR 63
39, DAC = 3855 CNTDR 62
3519, DAC = 3871 CNTDR 61
3524, DAC = 3887 CNTDR 60
3536, DAC = 3903 CNTDR 59
3529, DAC = 3919 CNTDR 58
3521, DAC = 3935 CNTDR 57
3520, DAC = 3951 CNTDR 56
3515, DAC = 3967 CNTDR 55
3522, DAC = 3983 CNTDR 54
3522, DAC = 3999 CNTDR 53
3522, DAC = 4015 CNTDR 52
3524, DAC = 4031 CNTDR 51
3519, DAC = 4047 CNTDR 50
3523, DAC = 4063 CNTDR 49
3531, DAC = 4079 CNTDR 48
3513, DAC = 4095 CNTDR 47
29, DAC = 3855 CNTDR 46
3518, DAC = 3871 CNTDR 45
3548, DAC = 3887 CNTDR 44
3526, DAC = 3903 CNTDR 43
3523, DAC = 3919 CNTDR 42
3547, DAC = 3935 CNTDR 41
3542, DAC = 3951 CNTDR 40
3538, DAC = 3967 CNTDR 39
3515, DAC = 3983 CNTDR 38
3528, DAC = 3999 CNTDR 37
3522, DAC = 4015 CNTDR 36
3518, DAC = 4031 CNTDR 35
3519, DAC = 4047 CNTDR 34
3519, DAC = 4063 CNTDR 33
3521, DAC = 4079 CNTDR 32
3519, DAC = 4095 CNTDR 31
41, DAC = 3855 CNTDR 30
3528, DAC = 3871 CNTDR 29
3535, DAC = 3887 CNTDR 28
3533, DAC = 3903 CNTDR 27
3525, DAC = 3919 CNTDR 26
3546, DAC = 3935 CNTDR 25
3523, DAC = 3951 CNTDR 24
3522, DAC = 3967 CNTDR 23
3548, DAC = 3983 CNTDR 22
3522, DAC = 3999 CNTDR 21
3549, DAC = 4015 CNTDR 20
3522, DAC = 4031 CNTDR 19
3519, DAC = 4047 CNTDR 18
3523, DAC = 4063 CNTDR 17
3554, DAC = 4079 CNTDR 16
3539, DAC = 4095 CNTDR 15
14, DAC = 3855 CNTDR 14
3519, DAC = 3871 CNTDR 13
3523, DAC = 3887 CNTDR 12
3523, DAC = 3903 CNTDR 11
3527, DAC = 3919 CNTDR 10
3532, DAC = 3935 CNTDR 9
3518, DAC = 3951 CNTDR 8
3545, DAC = 3967 CNTDR 7
3540, DAC = 3983 CNTDR 6
3525, DAC = 3999 CNTDR 5
3523, DAC = 4015 CNTDR 4
3541, DAC = 4047 CNTDR 2
3551, DAC = 4063 CNTDR 1
3537, DAC = 4079 CNTDR 256
3521, DAC = 0 CNTDR 255 // Continues periodically...
Could this be caused by some misconfiguration? Or is it maybe a hardware fault? (I doubt that, though...)
