I am trying to measure the current drawn by my entire circuit (which contains a few ICs and a microcontroller). Some of these components such as the microcontroller are connected using 'Hidden Pins' to power rails VCC and GND. How do i connect an ammeter in series with this to measure the current drawn by the MCU ? or is there a way i can measure the total current drawn by my circuit ?
Edit:
The solution provided in Connecting Switches to Hidden Supply Pins in Proteus ISIS does not solve the user's problem due to the following reason.
This is how we want the circuit to be.
Creating a schematic like this in Proteus will throw an error saying
No power supply specified for net SRC1 in Power Rail Configuration
If you try to fix this by following the answer in the link above and goto Design->Configure Power Rails
and add netlist SRC1 (our custom netlist) to VCC power rail, then we are essentially just creating a link from SRC1 to VCC. This essentially bypasses the switch and just connects the hidden pin VDD directly to VCC hence doesn't provide the intended result.
