I suppose in binary addition (no negative numbers), overflow happens when theres a carry out?
Then for subtractor (2s complement), how do I determine it? From my understanding of my lecture notes, overflow happens when theres a change in sign or carry in of MSB is different from carry out? Is that true?
Then suppose \$011_{2s}+001_{2s}=100_{2s}\$ the answer is correct, but carry into MSB is 1 but carry out is 0, so according the the rule above, its an overflow?
+ 001 (2s)
 0100
Suppose \$X\$ & \$Y\$ are my sign bits, \$S\$ is my MSB generated and \$C_{in}, C_{out}\$ are my Carry in & out. I will implement Overflow, \$O\$ as
Suppose the above were correct, I will implement the logic to determine an overflow like $$Overflow = (Sign 1 \odot Sign 2)(Sign 2 \oplus Carry Out) + (Carry In \oplus Carry =Out)$$
stevenvh
  • 145,145
  • 455
  • 667
Jiew Meng
  • 569
    We've changed the TeX delimiter to a backslash followed by a dollar sign, because dollar characters (read: money) in text were inadvertently interpreted as TeX. – stevenvh Sep 20 '11 at 06:59
From http://en.wikipedia.org/wiki/Two%27s_complement:
"The last two bits of the carry row (reading right-to-left) contain vital information: whether the calculation resulted in an arithmetic overflow, a number too large for the binary system to represent (in this case greater than 8 bits). An overflow condition exists when these last two bits are different from one another. As mentioned above, the sign of the number is encoded in the MSB of the result."
So your example, when done in 3 bits, has an overflow, because the carry into the highest bit is 1, the carry out of it is 0. (Also easy to see intuitively: you start with two positive numbers and end with a negative number). You tried to make things a bit confusing by writing the result in 4 bits, but you omitted the carry out of the 3th bit. When done in 4 bits there is no overflow, because the last two carry bits (into and out of the 4th bit) are both 0.
The correct way to note youre addition (in three bits) is:
 011
  011
+ 001 (2s)
  100
Wouter van Ooijen
  • 48,407
  • 63
  • 136
  • Oh, I meant to say theres a carry out of 0 which is different from the carry in. I dropped the carry out after that. Anyways, it means that I just need to check if the sign bits changed (if adding 2 positive or 2 negative numbers?). That will be the same as checking if the carry into MSB is different from carry out? – Jiew Meng Sep 20 '11 at 06:33
  • Yes, but that would be a very limited interpretation of addition. You also want to be able to add positive (including zero) and negative numbers, you you check as stated in the wiki quote: xor the two carries and you get the over/under flow. – Wouter van Ooijen Sep 20 '11 at 06:39
  • sorry I dont get what you mean? Can I say I just need to check if carry in is different from carry out? eg \$C_{in} \oplus C_{out}\$ – Jiew Meng Sep 20 '11 at 07:31
  • Yes, you need to checke whether carry into the highest bit is different from carry out of it. – Wouter van Ooijen Sep 20 '11 at 07:32
