I want to use a balanced line driver of the type DRV134 or THAT1646. With a bypass switch I want to bypass the IC and send the signal to another circuit instead. In order to null the output of the driver IC in case the switch is in the bypass position, I thought of shunting the input to ground via 10k. Is this the correct way of handling this situation? Is it the correct resistor value? The driver source is an op-amp with no resistor or cap between them.
(the other pole of this switch switches the input of the other circuitry, respectively)
