I have very basic knowledge of electronics.
I am looking for a circuit which can turn ON/OFF an LED from a single switch.
  • If the LED is OFF and the switch is pressed (even if not released) then the LED should turn ON.
  • If the LED is ON and the switch is pressed (even if not released) then the LED should turn OFF.
A switch can be a push to ON switch but turns OFF when released. It is not like a toggle switch.
Thanks in advance
Amit Kumar
  • 35
  • What parts are available to you? Would a D-Flip Flop work? – Tyler Oct 21 '15 at 02:29
  • Hi Tyler, I have 555 timer IC but can get other items as well. Just need a really simple solution to achieve this. – Amit Kumar Oct 21 '15 at 02:34
    Your solution is right [here](https://m.youtube.com/watch?v=Foc9R0dC2iI). It's called a "Soft Latching" power switch. Check it out – ezra_vdj Oct 21 '15 at 04:12
  • @ezra_vdj If the button is not released then the circuit will oscillate; the LED will flash. – CharlieHanson Oct 21 '15 at 11:35
  • @CharlieHanson If it's good enough for Dave Jones I'd say it's good enough. All depends on project, cost, who's using it etc though, you feel? – ezra_vdj Oct 21 '15 at 11:41
  • @ezra_vdj The OP implies that oscillation is not acceptable with "pressed (even of not released)". It may be good enough for Dave Jones - and plenty of others as this is one of the oldest tricks in the book - but if it violates part of the specification then it is not the solution. – CharlieHanson Oct 21 '15 at 12:34
  • Yep I don't want a flashing LED. Anyways thanks everyone for your time and help. I thought it will involve few components but I don't think there is any such design. I have to manage 10 LEDs and these designs will make my project bulkier. I have to find something else then. – Amit Kumar Oct 21 '15 at 23:32
This one is fairly simple: -
Each time you press the button, the output latches in the opposite sense to what it previously was. Lots of good ideas.
Picture stolen from this stack exchange question: Make a Latching Relay using SPDT Relays
Is this question all but identical?
  • Thanks Andy. The circuit looks OK but will not fit my project as I have to manage multiple LEDs. May be 10 or something. Do you have any suggestion? – Amit Kumar Oct 21 '15 at 23:34
  • Here is my exact requirement. http://electronics.stackexchange.com/questions/196598/circuit-to-indicate-1-to-10-based-on-pressed-switch-non-latching – Amit Kumar Oct 22 '15 at 00:09
  • I have answered this question for a single channel. Just step and repeat for multiple channels. I don't see the problem unless, of course, you have changed your mind about what you want. – Andy aka Oct 22 '15 at 09:21
  • I haven't changed my mind. I was looking for a circuit with less number of components. However, your answer seems to be more accurate than others. Thanks for your help. – Amit Kumar Oct 22 '15 at 23:26
