I use the following Colpitts oscillator schematic and I always need to put the scope probe on the inverting input of the opamp to make it start. Otherwise I get a DC voltage and no oscillations.
Do you have any idea about what I can do to to have a reliable startup at powerup ?
Thanks.
colpitts oscillator
akhmed
  • 205
user89544
Try reading this tutorial: -
Note the use of R3 to prevent the op-amp output being directly loaded by one of the capacitors. Theoretically you have to have some phase shift between output and first capacitor and therefore you need a resistor.
Note also that the gain in your circuit is far too high.
I'm not ruling out anything else too.
  • Yes - I agree to Andy`s recommendation regarding R3. The BJT acts as a current source - in contrast to an opamp which is a voltage source. For this reason an opamp based Colpitt oscullator needs such a resistor R3. – LvW Oct 20 '15 at 13:59
Given that this is an old question, I will provide another answer just for reference of future generations. As a fellow electronics student, I found the following simple Falstad circuit to be helpful in understanding Colpitts Oscillator with an op-amp:
akhmed
  • 205
