This is probably some stupid mistake, but I can't understand what's going on.
I have a Discovery board with STM32L100RC.
The HSI oscillator runs at 16 MHz and is selected as the system clock source, so everything should be running at 16 MHz. AHB prescaller is disabled.
According to the datasheet, the clock is divided by 8 before being sent to systick.
I have SysTick reload configured as 0xFFFFFF
(which would give me 1 Hz if SysTick was at 16 MHz). And I am getting 1 Hz SysTick interrupt.
Problem is, that would mean the main clock is running at 128 MHz - certainly not.
What would explain the SysTick frequency I am getting?
Is the datasheet wrong?
For completenes, code used for setting up the clocks:
ALIGN
RCC_CNF
PUSH {LR}
; FLASH timing config
LDR R0, =FLASH_ACR
LDR R1, [R0]
ORR R1, R1, #FLASH_ACR_ACC64
STR R1, [R0]
LDR R1, [R0]
ORR R1, R1, #(FLASH_ACR_PRFTEN :OR: FLASH_ACR_LATENCY)
STR R1, [R0]
; Enable HSI
LDR R0, =RCC_CR
LDR R1, [R0]
ORR R1, R1, #RCC_CR_HSION
STR R1, [R0]
; Wait for HSIRDY
ALIGN
NO_HSI_RDY LDR R1, [R0]
TST R1, #RCC_CR_HSIRDY
BEQ NO_HSI_RDY
; Select HSI as clock source
LDR R0, =RCC_CFGR
LDR R1, [R0]
BIC R1, R1, #RCC_CFGR_SW
ORR R1, R1, #RCC_CFGR_SW_HSI
STR R1, [R0]
POP {PC}
And my SysTick config code:
; Configure SysTick
LDR R0, =SysTick_CSR
LDR R1, [R0]
; use internal clock & enable counting
ORR R1, R1, #(SysTick_CSR_ENABLE :OR: SysTick_CSR_CLKSOURCE)
STR R1, [R0]
; Configure the reload register
LDR R1, =0xFFFFFF
LDR R0, =SysTick_RELOAD
STR R1, [R0]
; Enable SysTick interrupt
LDR R1, [R0]
ORR R1, R1, #(SysTick_CSR_TICKINT)
STR R1, [R0]
In the interrupt handler, I'm just toggling a LED.
