I am trying to find the D.E. that relates Vin to Vout.
KCL at A: $$\frac{A-V_o}{12} + \frac{A-V_i}{6} + \frac{1}{12}*\frac{dV}{dt} = 0\tag1$$
KCL at B: $$\frac{B-0}{10} + \frac{B-V_o}{10} = 0\tag2$$
\$2B=V_o\$ or \$B = .5V_o\$
By using op-amp rules V+=V-(A=B) I found the following equation.
$$\frac{3}{2}V_o = \frac{dV_i}{dt} - 2V_i\tag3$$
I don't really know if this is 100% correct and would like to see what someone else comes up with.
nidhin
  • 8,197
user3482104
  • 99
    The answer is wrong. Equations (1) and (2) are correct. You made some mistakes while combining them. – nidhin Oct 14 '15 at 09:21
  • As a matter of building good notational hygiene, you might want to use \$V_A\$ and \$V_B\$ respectively instead of A and B in situations like this. It's a detail, to be sure, but helps clarify your expressions. On first take I was wondering what you were doing subtracting a voltage from a gain, as \$A\$ is often used to denote the gain ("**A**mplification") of an op amp. No better time than while you're learning to form good habits :) – scanny Oct 15 '15 at 19:28
By using op-amp rules V+=V-(A=B) I found the following equation....
You are not allowed to apply these rules because the equation (V+=V-) does apply only if the opamp is working linearly. However, this is not the case, because positive feedback overrules negative feedback. That means: The opamp does not work - it goes immediately into saturation.
In case of a drawing error (both opamp inputs interchanged) we have a damped Deboo integrator (1st order lowpass) with the transfer function
H(s)=4/(12sC+1)=4/(s+1)
It should not be a problem to transfer this equation into the time domain.
LvW
  • 24,857
  • 52
  • At low frequencies , the cap acts as an open circuit,and since the series 6 ohm resistance is less than bridge resistor 12 ohm ,the negative feedback should dominate right? refer [link](http://electronics.stackexchange.com/questions/112472/how-are-positive-and-negative-feedback-of-opamps-so-different-how-to-analyse-a) – Ashik Anuvar Oct 14 '15 at 16:22
    No - the negative feedback factor is (-6/18=-1/3) and the positive feedback factor is larger (+1/2). Hence, the circuit goes immediately into saturation. Therefore, you must exchange the opamp input terminals. – LvW Oct 14 '15 at 17:14
the differential equation is wrong,please recheck your steps. The actual DE is
$$\frac{dV_o}{dt} + V_o = 4V_i$$
Update: However the differential equation is not valid as negative feedback fails to dominate here,the concept of virtual short circuit fails and op amp is in saturation!
Ashik Anuvar
  • 708
    This diff. equation applies only if both opamp input terminals are interchanged. – LvW Oct 14 '15 at 10:49
