I work with microcontroller LPC2368.
After initialisation of the CAN interface to normal mode (not listen-only mode), I can receive all messages, but the microcontroller cannot send an acknowledge with the error code in register CAN1ICR->ERRBIT = 0X19 (Acknowledge slot).
In the same way, the microcontroller can't send a message on the CAN bus with error CAN1ICR->ERRBIT = 0x03 (Start of frame). Why can the microcontroller receive all messages, but have problems when writing on the line?
Peter Mortensen
  • 1,676
Sauber
Referring the user manual, this error status is triggered as a result of errors occurring when other nodes on the bus dont ACK that they received a message successfully. This can be due to, variable baud rates among the nodes or simply using just 1 node on the bus and sending a message. Make sure all nodes are configured to have the same Baud rate and a minimum of 2 nodes are connected to the bus.
Additionally, to can also perform an bus loopback using only 1 node by enabling Self Test Mode(no need of ACK to declare that a message has been sent successfully) and Self reception request(Reflect TX differential data into the Rx buffer) and check if the transmitted data is correct.
This can be checked by probing to see if the start of frame TTL Tx signal appears as a differential signal on the bus. Check the transceiver functionality as well.
AlphaGoku
  • 1,003
  • 26
