20
What are some paths for a child (7-year-old) to learn electrical engineering (in a safe way)?
I do not want to saturate (or frighten away) the child with lots of concepts, I want that my son learn playing with the basic and core of electrical engineering.
Or is 7 years not an age to learn electrical engineering? Or is it dangerous? I will always be by his side.
Null
  • 7,448
moonw
  • 131
  • Those are both robotics based (which is off-topic here now) but might be of interest to you. I thought there were other questions that were more like your question, but I am having a hard time finding them. – Kellenjb Sep 09 '11 at 16:57
  • Not to nitpick over wording, but considering we're talking about a 7 year old, you might want to change the title's wording "electrical engineering" to "basic electronics". – Radian Sep 14 '11 at 17:26
  • I will not select an answer, all answers are very good points of views. sorry. – moonw Oct 03 '11 at 20:02
13 Answers13
14
This question may be off-topic but I'll take a stab anyways.
I wish I had Lego Mindstorms when I was a kid: http://mindstorms.lego.com/en-us/Default.aspx
The ease of construction with lego and pre-fabricated parts will definitely suit a child - at that age they may not have the manual dexterity to build their own projects using tools like wire strippers or a soldering iron. Mindstorms also has a programming element to it, using a version of LabView - these days, I believe programming is an essential part to learning electronics/electrical engineering. Others may disagree with me on that point but I think it's a good thing to learn anyways as it teaches how to think logically.
After this, your child may decide to move in to different directions, either lower level (how things like transistors and motors work) or higher level (more interested in programming and control). Moving to a platform like the arduino and building things from scratch would be an interesting next step.
EDIT: Lego Mindstorms recommended ages: 10-up, so this may not be suitable for a 7-year old.
Jon L
  • 4,258
  • Also, in my country is not easily to get a Lego Mindstorm (also seems expensive to send to my country), I will try to review how is possible. – moonw Sep 09 '11 at 19:55
  • @moon.watcher, what country are you in? It may help us with recommending resources. – Jon L Sep 09 '11 at 22:54
  • Lego Mindstorms is great for learning at the right age, but that age is not 7 years. Hold that thought until early middle school. – Olin Lathrop Sep 09 '11 at 22:56
  • @Olin Lathrop, You're probably right on that one. Edited with information on recommended ages. – Jon L Sep 09 '11 at 23:07
  • The only problem with Lego is that you can never have enough Lego... – Faken Sep 09 '11 at 23:42
    If the kid is interested, the age gap shouldn't be a problem. – RoundTower Sep 10 '11 at 02:31
  • Indeed one week ago we interact with a Lego Mindstorm and My son became fascinated (and I). I found today a place to import Mindstorm in my country (is Colombia), but the value is 4 times the value in USA, so is expensive :( – moonw Sep 10 '11 at 04:36
    lego mindstorms are expensive no matter what the country. I'd start him out with some brand of arduino and get him gluing/mangling lego to get motors attached to it. Lego Technik (the gears and such) are relatively cheap and I think are better suited for learning – akohlsmith Sep 10 '11 at 22:13
  • I do not want select an answer, all answers are very good points of views. sorry. – moonw Oct 03 '11 at 01:28
  • @moon.watcher, not a problem. This has been turned into a community wiki now, so it makes sense that there is no right answer, just a general collection of advice for this topic. – Jon L Oct 03 '11 at 05:54
At that age you need to keep it very basic and watch for what really interests him. A lot can be done with a few light bulbs, switches, relays, electromagnet, and a small motor.
Get a decent set of alligator clip leads. Wobbly connections can frustrate and discourage, but it also has to be easy.
I got a bell around that age, and I remember it being really cool how it would self-oscillate by breaking it's own connection when the hammer moved too far. Be patient as this may take a little to understand. You can make a buzzer with a relay too, but the result isn't so dramatic.
Olin Lathrop
  • 310,974
  • 428
  • 915
  • very thanks for your suggestions, also I must be patient, I want that my son find this interesting. Also I must learn about this, to keep the interest of my son moving. – moonw Sep 09 '11 at 19:50
Get a bunch of random electronic stuff and encourage him to take it apart & generally tinker with it. Teach him to solder and unsolder.
mikeselectricstuff
  • 10,655
    -1 for soldering and unsoldering for a 7 year old due to safety; -1 for unsoldering potentially leaded solder. – Brian Carlton Sep 09 '11 at 23:32
  • Get a bunch of random electronic stuff and discover things is a curious idea!!!. about teach to solder, I do not know nothing about electronics or electrical engineering, so I am not the person to teach to solder to a kid of 7 years. Also seems that could be dangerous. – moonw Sep 10 '11 at 04:34
  • Lead in solder is not an issue. You certainly want to at least start with leaded as it's easier so they are less likely to give upinfrustration. As regards soldering, it depends a lot on the level of the kid's common sense at what age to start - obviously start under supervision and evaluate over time. After their first burn they will learn not to touch the hot end. – mikeselectricstuff Sep 10 '11 at 14:11
    agreed with mikeselectristuff... don't turn this into some kind of overprotective no-fun zone. soldering for a 7 year old is NOT hard. I had my 6 year old daughter soldering (with my assistance of course) but a 7yo should be able to handle such a thing without putting themselves in danger. – akohlsmith Sep 10 '11 at 22:19
  • Yeah, 7 is not too early to learn soldering, with proper supervision of course. When I was in first grade, my father and I built a crystal radio kit together, which he used to introduce me to soldering. I must have been 6 at the time. Of course I was crappy at soldering for quite a while after that, but there is nothing wrong with introducing a 7 year old to soldering and getting him to practise by building a few things. Be tolerant of large solder blobs at that age. – Olin Lathrop May 30 '13 at 18:52
Many children enjoy putting together simple stuff that emits light and/or sound. An assortment of LEDs and resistors, breadboard, and a battery may be enough to get started. For more difficult things you may want to try kits.
I bought Make: Electronics recently. This is a very hands on book. It explains how to blow things up in an almost Mythbusters style (e.g. fuses and LEDs). It's all safe though - so suitable for a seven year old I would say.
ubiyubix
  • 183
I started my kid off with Snap Circuits when he was quite young. They come in different sizes - get a small one first and if he likes it then you can get one of the bigger ones later.
Paul R
  • 752
You can teach/learn some concepts with a simple model railroad lyout. I remember learning something about shorts and opens, switches, solenoids, tranformers, and parallel and series circuits from working on a train layout.
I also remeber making a simple electromagnet using insulated wire and a big bolt, powered by said train transformer.
B Pete
  • 2,832
  • thank you!, I will review how to build your suggestions, I do not know about electrical engineering, I must learn too!. – moonw Sep 09 '11 at 19:53
It doesn't take a whole lot, at least not initially. I got started with making 'flashlights' and buzzers from scratch, must have been about 6 or 7 years old. My father showed me how to make a flashlight bulb work with a battery. Not long after that, how to wind a bunch of wire around a nail set in a piece of wood, bend some thin sheet metal into shape so the electromagnet could pull it down, and set another nail or sheet metal piece to act as a normally closed contact. These items could be run satisfactorily from a single 1.5V flashlight battery. The most dangerous thing was probably the sharp edges on the sheet metal. Being a kid, I must have built dozens of variations on these before it got stale. After that it was a 'make your own motor' kit from the local R.S., and then on to the spring-clip 150-in-1 kit type things.
In retrospect, I think this trajectory worked because at least initially, there really wasn't any quantitative stuff to worry about. There was immediate gratification in seeing a light come on, or a buzzer sounding, and it did help establish the idea of a 'circuit', with simple loops of things in series. Plunging in with resistors and capacitors and transistors straight away would probably not have held the interest of the 7-year-old mind.
JustJeff
  • 19,163
  • 75
  • thanks for take time to answer, I appreciate your comment and I will take it into account. I will try to keep the attention and interest of my son trying to use basic things to keep visible and understandable the basic concepts. – moonw Sep 10 '11 at 04:23
Though the Lego Mindstorms kits may be too hard for some grade schoolers, Lego has a WeDo robotics construction kit that's targeted at even younger budding robotics hackers; it's rated at 7+. My eight year old daughter liked hers, she asked for it for last Christmas (actually two years ago now that I think of it). Bonus, the software is a simplified version of the Mindstorm software, which is a simplified version of LabVIEW, so you get 'em on an upgrade path that ends with real engineering.
I remember my first experience with electricity in school was when we got a bench power supply, a potentiometer, and a few wires, and were invited to experiment. We learned that for a few configurations nothing happened (very educational!), but if we connected it the right way we saw the current meter go up and down when we turned the potmeter's knob. We didn't understand yet what actually happened, but we felt like magicians. Later the teacher explained about current and resistance.
So that's one way to get started. You need a decent, current limited, power supply, so that the experiments can't do any harm. A 9V battery may be an alternative. Let the boy play with small lamps (LEDs are more vulnerable) and switches, and teach him about parallel and series switches. Let him construct a buzzer with a relay.
He'll be most interested and eager to learn if he can see or hear something happen.
edit
I wouldn't expose the kid to electronic parts, not even a diode, until he fully understands voltage and current. A diode may look simple to explain, but it's no use explaining it if you can see him think: "Yes, current... what was that again?"
stevenvh
  • 145,145
  • 455
  • 667
  • thanks a lot for your suggestion, I will try to research ways when he can see or hear something happen. – moonw Sep 09 '11 at 19:45
  • diodes aren't hard to explain, especially light-emitting ones. It's a one-way street or a valve (depending on their understanding of the world so far) -- transistors I didn't truly "get" until much, much later. – akohlsmith Sep 10 '11 at 22:16
Many sources sell hobby kits for children which may be useful to you as a starting point. They generally use batteries instead of mains-connected parts, which can be seen as a risk reduction. (You can still short batteries and make a nice mess, but to me it's still safer than AC!)
As your child gets older, there are more sophisticated kits available.
Most of these kits specify 8 years and up, so supervision and patience will be needed.
Adam Lawrence
  • 32,921
  • 58
  • 110
  • your suggestion and suggestion of Paul R seems alternatives pedagogically focused to kids!!. I must review your alternatives also with other suggestions. thanks a lot! – moonw Sep 10 '11 at 04:00
  • http://www.apogeekits.com/lab_kit_el301.htm is the exact first kit I started with many, many years ago. My father bought it for me from Radio Shack, and it was rebranded for the store, but the kit still exists, is still very fun and is still an EXCELLENT place to go once they show some basic interest. This kit is NOT a first step, but a second. – akohlsmith Sep 10 '11 at 22:22
My start was a crystal radio kit, not much more than winding a coil of wire, a diode, and earpiece. But, listening to AM radio stations got me hooked. Next was a Radio Shack 150:1 electronics kit, followed by a ham radio license.
Kits like this are an excellent introduction to electronics and just as much fun for parents helping their interested children.
Jim A
  • 128
After being safe, the most important criterium is that the kid must like it.
My own kids (7,9,11) love to break things apart. When a new PC, CD player, or whatever arrives they immediately ask when (note: not 'if'!) they can take the old one apart. A classmate of one of my kids is totaly wild about LEDs. Bristelbots are also popular. For one of my kids I made a few componets (LED+resistor, switches, battery) on wood pieces, with alligator clip cables to connect them. He also has an old philips-style experiments set. A nephew was wild about the nightrider-display kit I gave him. When I was young I made crystal radio's for all my friends, and I put simple battery/inductor shock generators my room's doorknop (my sisetr did not like that, neither did my mother when she told her).
Roundup: experiment, find out what your kid likes. When it is powered by a few penlight batteries (no rechargeables!), and does not try to generate high voltages stored in a capacitor, it is unlikely to do any harm.
Wouter van Ooijen
  • 48,407
  • 63
  • 136
I started with batteries, wires, light bulbs and switches. Building simple logic circuits was endlessly fascinating. I moved on to a Digi Comp plastic toy computer. Later I learned about voltage, current, resistance, and how to solder.
Kits are very valuable, but I think the important thing is to let the child's direction of greatest interest be the guide. You can expose your son to lots of different possibilities but he'll be the one who picks up something and runs with it.
Regarding safety, the list of dangers isn't too long. There are high voltages, chemicals, hot things and sharp things. Later there might be other dangers (lasers can hurt retinas, and large electrolytic caps can explode) but those won't be immediate concerns. To keep voltages low enough to be safe, stick with batteries or wall wart power supplies. You're the best judge of whether he's ready for a soldering iron; if yes, find him some safety goggles.
Will Ware
  • 86
