Our circuit is like following: enter image description here
There are four layers, including top, power, ground and bottom.
My way of grounding:
I follow the instruction by Maxim: https://www.maximintegrated.com/en/app-notes/index.mvp/id/5450
As it introduces, there is no need for a cut in ground plane. Since the return currents from analog circuits will not overlap with the return currents of digital circuits. And the high frequency currents will be absorbed by the small capacitors.
However, we recently hired a very professional consultant company to help us design a newer version. They design in a different way.
The consultant way
They cut the ground plane into two: analog and digital. And connect the two planes with 0 Ohm resistors when necessary. They are very professional, so I start to think in their ways.
What I think their way could be good: Without cutting, the digital return currents still have the chance going into the analog ground.
What I think may be bad: There could be several connections between the analog ground and digital ground. There would be ground loops and become antenna.
Could I have comments here?
richieqianle
  • 1,612
  • 44
  • There is no reason to split planes if you know what you are doing and aware of return currents. – efox29 Sep 24 '15 at 14:49
  • Do you mean that you support the first way of routing? – richieqianle Sep 24 '15 at 14:56
    Yup. I've read books from Eric bogatin, Henry ott, Howard Johnson and recently went to pcb west, what they all more or less say, if you understand how current flows on a pcb, there is no reason to split planes. If your return currents don't overlap (analog and digital) and have a good pdn, proper layer stack, you'll be just fine. Rick Hartley would call your consulting company, and I'll use what I think are his words " a bunch of idiots that don't know what they are doing". Lol Rick Hartley is the best. His talks were informative and humorous. – efox29 Sep 24 '15 at 15:01
  • Not sure why this question was down voted. I think it's a valid question with a good body of text. – efox29 Sep 24 '15 at 15:02
  • What is pdn? Sorry for my ingorance – richieqianle Sep 24 '15 at 15:03
  • Pdn - power distribution network. It's how you get your power to all your various components. – efox29 Sep 24 '15 at 15:06
    There's no need to cut the planes as @efox29 says. Sometimes it can be useful to be able to change the location where the GND planes meet each other. For example where the entrance to the peninsula will be. In that way I suppose a 0Ohms is convenient but if you go that path I'd make sure there were plenty of vias and the connection was as low impedance as possible. Personally I would not choose that path. – Some Hardware Guy Sep 24 '15 at 15:12
  • Could you explain the entrance of peninsula? – richieqianle Sep 24 '15 at 15:47
  • @SomeHardwareGuy For multiple ADC, DAC, do you think the 0 Ohms will cause ground loops? And will the ground loops be problems? – richieqianle Sep 24 '15 at 15:48
  • For multiple ADC I would refer you to Dr. Johnson's article about it here http://www.sigcon.com/Pubs/edn/multipleadc.htm – Some Hardware Guy Sep 24 '15 at 15:50
  • What do the consultants do for the ADC and DAC where the "two" grounds meet? The maxim article is pretty good. – George Herold Sep 24 '15 at 16:02
  • @GeorgeHerold why is single point ground important? The consultants use the way that there are two different connections on ground. – richieqianle Sep 24 '15 at 16:28
  • I think that Maxim article is excellent. Was the ADC performance adequate on your original board? If so, do not split the planes. But if you are hiring these consultants to improve noise performance of the board, then maybe you should take their advice. Give them a chance to prove they know what they are doing. One caution: if this board has to pass radiated emissions testing, I would strongly urge you not to split the GND plane. – user57037 Sep 24 '15 at 17:48
  • As mentioned. be mindful of the return current. see here https://electronics.stackexchange.com/questions/128637/how-should-i-connect-agnd-and-dgnd –  Sep 25 '15 at 08:49
Splitting planes 'as a matter of policy' is almost always bad. It means the people advocating it can't think their way through what needs to be done, so fall back on rules of thumb. Zero ohm resistors connecting regions may be useful to save the perpetrator's faces when in last-minute hacking to reduce problems, these links are randomly connected and removed until hopefully the circuit scrapes into spec.
Just because you write '0v' on a circuit diagram doesn't mean it's ground.
Trace the signal currents 'out' through the circuit, and expect the ground current to return on the ground layer parallel to the signal path (this is Maxim's path of least AC impedance). If it can't, because of a cut across the ground plane (I hate those ground flood fills, that then later get cut into lace-curtains by added signal tracks), then you have a problem. I like to route my grounds, as traces, parallel to my signals. Soon, those traces will start to form loops. Each time a loop forms, that's a good point to evaluate just what current path through what ground impedance may be presenting a small voltage to somewhere else. If you have a problem with these ground paths, then you change your floor plan now to untangle them. It's easier to do it piecemeal at this stage, than route the whole board and then try to untangle it. Eventually, the whole ground gets filled anyway.
If a high current curcuit dumps current into one end of a trace, any other circuit sharing that trace will see some of the stray voltage developed across it.
That Maxim link is one of the clearest guides I have read for what to do. However, be warned, it is very difficult to keep your head and apply it, with a lot of ICs on the board, and some expensive consultants snapping at your heels and wining and dining your boss to win him over. Remember, professional means they take money for what they do, it doesn't unfortunately mean they understand what they are trying to do. Good luck.
Neil_UK
  • 158,152
  • 173
  • 387
  • The maxim tutorial keeps mentioning single point, why is that important? – richieqianle Sep 25 '15 at 00:00
  • "Remember, professional means they take money for what they do, it doesn't unfortunately mean they understand what they are trying to do." Love it. Well said. – efox29 Sep 25 '15 at 21:41
Some time ago, I answered a similar question here.
The first sentence, which is an echo of commenters here is:
Unless there is a compelling reason otherwise, I use the same ground everywhere.
The Maxim application note is targeted at mixed signal integrated circuits, where, unless you take precautions, the digital and analogue currents will overlap, and the usual method of managing this is to tie the effective digital and analogue grounds is at a single point (usually beneath the device).
Understanding how the currents move in the plane(s) is the key to good signal integrity, and the general rule of putting the sensitive circuitry furthest from power and the noisy stuff close to it is a good rule of thumb, but every design needs to be analysed for clean power and grounds (the return path which is the 50% of the power that does not seem to appear in a schematic but is just as important, of course).
[Update]
Under very limited circumstances, a split plane may be appropriate. There is a trade-off of effort vs. return on that effort. In an ordinary mixed mode system, I would not split the planes.
The example was a specific design that had very high eddy currents on the LEDs where it was easier (and appropriate) to split the planes to prevent those eddy currents from inducing into the other LEDs. The grounds were tied together at the primary power inlet to the board.
I think my primary point on where things are placed is that sensitive devices should not have return currents from other devices under them. In a system with high speed logic and ADCs, I would put the ADCs at the end of the power path so that the digital returns cannot interfere with the measurements.
Perhaps I had not made that as clear as it could have been.
HTH
Peter Smith
  • 21,923
  • 64
  • 1. Do you mean under certain circumstances that splitting the ground may be a good choice? 2. I am not sure if I agree with you that analog circuits shall be furthest. The digital circuits will generate noises on ground and they will be coupled into sensitive analog circuits. – richieqianle Sep 25 '15 at 08:22
  • I think you are correct that the digital currents will not enter the analog region. However, the analog region will be referenced to the ground at the connection between analog and digital. The reference has noises. – richieqianle Sep 26 '15 at 07:56
