A year or so ago I built a simple gauge for the fuel oil tank in my basement using a MaxSonar-EZ ultrasonic distance sensor. At some point, it stopped working, and when I removed it from the tank today, I found that there's quite a bit of black … uh, "stuff" on portions of the PCB, wires, and pads. I'm assuming it's corrosion of some kind. Although it's not outside of the realm of possibility, I don't believe the sensor got splashed and I know it wasn't submerged. I don't know if the transducer is itself damaged. I never liked that sensor much, so I've got a Parallax one that I intend to put in it's place. I'd like to find a way to make this sensor more resistant to the environment (assuming it's the environment that's caused the MaxSonar unit to die), or find a better replacement. I'm fairly confident that I can protect the Parallax sensor's PCB from the air in the tank with some acrylic sheet and Permatex gasket maker, but the transducers will necessarily be exposed. I'm not sure this is sufficient, however. I'd appreciate other suggestions on how to make a more durable gauge!
Thanks, Brian
