I'm building a device using
  • TUSB2046B hub controller
  • 4x FT230X USB to UART controller
First, let's look on Hub controller sample application:
TUSB2046B Application Note
Note D:
All USB DP, DM signal pairs require series resistors of approximately 27 Ohm to ensure proper termination. An optional filter capacitor of about 22 pF is recommended for EMI suppression. This capacitor, if used, must be placed between the hub terminal and the series resistor, as per section 7.1.6 of the USB specification.
Then let's look on FT230X sample application:
FT230X Application Note
My questions:
  • What is the purpose of 15kOhom resistors to ground on first image? Are they necessary in single pcb layout?
  • How should I connect those two devices assuming single pcb layout with no more then 5cm distance?
This is the most intuitive idea:
And some questions:
  • Can I safely remove one 27 Ohm resistor on each line? Must I change the remaining one to 54 Ohm?
  • Is there any difference whether capacitors are 22pF or 47pF?
  • Are those capacitors necessary?
peku33
  • 395
  1. The 15kOhm pull-down resistors are most definitely required. The slave device has internal pull-up resistors on one or both of the DM/DP lines which are used by the host to detect that a slave has been attached and its type - low, full or high speed. You need these pull-down resistors to ensure the line isn't left floating or this detection won't work properly.
  2. You can omit the termination resistors and capacitors. They have two purposes: the first is to prevent reflections from the end of the lines which would cause fading interference with the signal. However, since you are only running the bus in full speed mode (12Mbps) and the line length (5cm) is much much shorter than the wavelength of the signal and its main harmonics, reflections aren't going to be an issue. The second purpose is as a line filter to reduce the EMI generated by the USB cable. You might need some sort of filter to pass EMC tests, but you should just treat the bus lines as you would any other digital lines you have on your board. Note that most USB drivers are slew rate limited so you are already much better off EMC wise than a GPIO line driving your LCD or whatever.
Jon
  • 4,894
  • Ad 1. Why there is no pull-down resistor on hub-to-pc minus line? There is only pull-up on plus (for speed negotiation). – peku33 Sep 03 '15 at 23:36
    @peku33. USB is not a symmetric bus - the role of hosts and devices is different. A hub is a device to the up-stream PC, and a host to the down-stream devices connected to it. So the pull-up on the hub-pc connection is to tell the pc (host) that the hub is a full speed device. That probably sounds a bit confusing. Have a read of the first couple of chapter of USB Complete (Jan Axelson) and it should help you a lot. – Jon Sep 04 '15 at 08:15
  • Ok, I understand that part about pullup for speed negotiation, but I still don't understand the role of 15k pull-down. Without pulldown on hub upstream, minus line is left floating. – peku33 Sep 04 '15 at 10:35
  • The up-stream 15k pull-downs are inside the pc. – Jon Sep 04 '15 at 10:52
  • So what happens when the data cable is disconnected, but hub is powered up? – peku33 Sep 04 '15 at 13:34
  • @peku33 - that is called a self-powered device. Basically the hub has to detect whether there is +5V present on the upstream connector (which indicates that the data cable is attached), even though it doesn't need power from it. When the +5V is not present it can just enter a disconnect or sleep mode - really what ever you want but I think most hub ICs would reset any downstream devices and go to sleep. – Jon Oct 02 '15 at 07:51
