I'm an old-school PIC assembly-type person, so my suggestions may not be applicable to what you are doing. But in general, I document what the port pin is doing right at the point in the code where the pin is defined.
Here is an example:
ADC_INIT EQU b'00000100' ; ra0,1,3 = a/d ra2,4,5 = digital
;NOTE: RA3 is a/d so that RA0,1 can be A i/p: watch out for R-M-W accesses!
; PORT A Device Bits note: ra 0,1 a/d inputs so no labels for them
#define _MUXCLK RA,2 ; RA2, a/d ext mux clk out (active LO)
#define _MUXRST RA,3 ; RA3, a/d ext mux reset out (active HI)
#define _PBWR RA,4 ; RA4, "WRITE" button (active LO)
#define _PBRD RA,5 ; RA5, "READ" button (active LO)
RA_INIT EQU b'00010000' ; turn off open drain o/p ra4 (early '71s)
DDR_A EQU b'00110011' ; ddr: ra 2,3==out, ra 0,1,4,5==in
DIPWRMSK EQU b'00010000' ;
DIPRDMSK EQU b'00100000' ;
;WARNING: Output pin MUXRST is configured as a/d input in ADCON1 (the smallest
;possible a/d input configuration) which means that it ALWAYS reads 0 for
;digital i/p. Any port A R-M-W instructions such as bsf, bcf, tstf, xor, ior
;will force MUXRST LO. MUXCLK is also o/p: anytime MUXCLK changes, MUXRST will
;go LO. Reccomend NEVER to use any other pins on port RA as outputs.
; PORT B Device Bits
#define _IPCRXD RB,0 ; RB0, IPC data input (active LO)
#define _IPCTXD RB,1 ; RB1, IPC data out (active HI)
#define _DHTRLD RB,2 ; RB2, display heater LEDs data output
#define _DSTAT RB,3 ; RB3, display status & inputs (bidirectional)
#define _STROBE RB,4 ; RB4, ctrl, DipSw, display strobe, eeprom !CS
#define _SERCLK RB,5 ; RB5, ctrl, DipSw, display CLOCK
#define _EECLK RB,6 ; RB6, eeprom clock
#define _SERDAT RB,7 ; RB7, ctrl, DipSw, eeprom DATA (bidirectional)
RB_INIT EQU b'00000001' ;initial port B data status
DDR_B EQU b'10001001' ;ddr: rb 1,2,4,5,6==out, rb 0,3,7==in
DDR_BLO EQU b'10001001' ;AND 0s force bits LO
DDR_BHI EQU b'00000001' ;OR 1s force bits HI
; PORT C Device Bits
#define _LCD0 RC,0 ; RC0, LCD bit 4 Note: 4 bit mode: present
#define _LCD1 RC,1 ; RC1, LCD bit 5 upper nybble first, strobe,
#define _LCD2 RC,2 ; RC2, LCD bit 6 present lower nybble, strobe
#define _LCD3 RC,3 ; RC3, LCD bit 7
#define _LCDS RC,4 ; RC4, LCD reg select: 0==command 1==data
#define _LCDE RC,5 ; RC5, E clock: normally ==0, pulse 1 to strobe
#define _SRTX RC,6 ; RC6, RS-232 Tx bit
#define _SRRX RC,7 ; RC7, RS-232 Rx Bit
RC_INIT EQU b'00000000' ; initial port C status
DDR_C EQU b'11000000' ; port C ddr: rc0..6==out, rc7==in
;b6==i/p till board layout error fixed or patched
; main board control s/r bits all outputs active HI
;b0=K8 b1=K7 b2=K6 b3=K5 b4=K4 b5=K3 b6=K2 b7=K1
#define _MGAS_M MAINRLY,0 ;24 Vac main gas valve
#define _BLOWR6 MAINRLY,1 ;exhaust blower 6
#define _BLOWR7 MAINRLY,2 ;exhaust blower 7
#define _PRHT2 MAINRLY,3 ;1== preheat ON
#define _PRHT1 MAINRLY,4 ;1== preheat ON
#define _Z1GAS MAINRLY,5 ;1== zone gas ON
#define _Z1SBY MAINRLY,6 ;1== standby mode (0==full heat)
#define _SW24V MAINRLY,7 ;24 Vac Power relay
; expansion board control s/r bits all outputs active HI
#define _PRHT4 EXPRLY,0 ;1== preheat ON
#define _PRHT3 EXPRLY,1 ;1== preheat ON
#define _Z4SBY EXPRLY,2 ;1== standby mode (0==full heat)
#define _Z4GAS EXPRLY,3 ;1== zone gas ON
#define _Z2GAS EXPRLY,4 ;1== zone gas ON
#define _Z2SBY EXPRLY,5 ;1== standby mode (0==full heat)
#define _Z3GAS EXPRLY,6 ;1== zone gas ON
#define _Z3SBY EXPRLY,7 ;1== standby mode (0==full heat)
;off board relay control bits
;b0=K1 b1=K2 b2=K3 b3=K4 b4,b5=dip sw mux b6=K5 b7=K6
#define _MGAS_O OFBRLY,0 ;110 Vac main gas valve
#define _BLOWR1 OFBRLY,1 ;blower 1
#define _BLOWR2 OFBRLY,2 ;blower 2
#define _BLOWR3 OFBRLY,3 ;blower 3
#define _DSMUXB OFBRLY,4 ;dip sw selector mux ctrl bit B
#define _DSMUXA OFBRLY,5 ;dip sw selector mux ctrl bit A
#define _BLOWR4 OFBRLY,6 ;blower 5
#define _BLOWR5 OFBRLY,7 ;blower 4
;NOTE: background routines write OFBRLY bits 0-3 and ignore OFBRLY bits 4-7.
;Dip sw mux bits are mapped to bit positions 4&5. OFBRLY bits 4&5 are mapped
;into bit positions 6&7. OFBRLY bits 6&7 are ignored and are intended to be
;used as flags for blowers 6&7 (MAINRLY bits 1&2).
;local trinary switch inputs (SW1EVEN, SW1ODD)
Z1MASK EQU b'10000000' ;zone 1 mask
Z2MASK EQU b'01000000' ;zone 2 mask
;Z3MASK EQU b'00100000' ;zone 3 mask
BTHOLD EQU b'00010000' ;batch timer hold: 00=once, 11=always
STRTCAN EQU b'00001000' ;batch timer start - stop switch
UPDN EQU b'00000100' ;batch timer up - down switch
