This is a follow up question based on this.
I have an ebike which uses lead acid battery, my question is do I need to fully drain it before charging it again?
How about when the battery is newly bought, any changes in charging it?
No, you should NOT fully discharge a Lead-Acid battery.
The normal reason for wanting to fully discharge a battery is because some batteries have a so-called "memory effect" - old NiCd cells are notorious for this.
But Lead-Acid does NOT suffer from this effect.
In addition, you can cause permanent damage to some of the individual cells within the battery if the battery is discharged too deeply - the polarity of the weaker cells can actually reverse polarity. This causes permanent damage to those cells.
Depending on which exact Lead-Acid battery you have, end of life discharge voltage for a nominal 12 Vdc battery (6 cells) ranges from 10.5 Vdc to 11.5 Vdc. The manufacturer of your particular battery will specify what the minimum allowable voltage is.
Batteries as a rule should not go below a certain safety level. If you drain a battery below a drastic level it needs a lot of current or amperes to kick it back to life. This would mean drawingin a lot of current from the charger and it could be an adaptor or such equipment which is never good.
Most professionaly designed equipment has a battery overvoltage and overdischarge protection circuit. Ricoh and Sieko Instruments make dedicated ASICs for such applications. You can look at Seiko Instruments S8204 chipset for more application information.
