I am a beginner trying to gain a better understanding of transistor codes. Before posting this, I searched the web looking for answers but I was unsuccessful.
Please take a moment to look at the transistors picture below:
Here are my questions:
Unless I am wrong, all of the transistors on the picture are supposed to represent the 2222 transistor. If this is the case, then why aren’t all those transistors specs identical? Isn't the 2222 supposed to exactly define the transistor properties construction, behavior etc? If yes, shouldn’t all have identical properties?
All of the transistor have a suffix. The first one has “A338”, the second “F42” and the third “B25”. What do those values stand for? If they are specified on the spec sheet could someone please point out to me where because I was not able to find them.
You will notice that the second transistor has a dot or dash before the “F42” and that the third transistor has a dot at the beginning and one at the end of its code. What do those dots / dashes represent?
The third transistor is specially weird (at least to me) because it seems to combine values that the other two do not. Specifically, its first line has the text "P2N2" when I would have have expected to only see the "P2N” text and on the second line the text "2222A". I am assuming they did this due to lack of space which makes me wonder if the dots around the text signify that the code should be read as a single line and not as a multiline?
Thanks for your help.
