I have a short UCF file with the following content:
## Fan Control
## Bank: 15
## VCCO: 1.8V (VCC1V8_FPGA)
## Location: J48, Q1
NET "FanControl_PWM" LOC = "BA37"; ## Q1.Gate; external 1k pullup resistor
NET "FanControl_Tacho" LOC = "BB37"; ## J48.3; voltage limited by D2 (DDZ9678 - 1.8V zener-diode)
NET "FanControl_*" IOSTANDARD = LVCMOS18;
# Ignore timings on async I/O pins
NET "FanControl_*" TIG;
This file bounds two physical pins to two top-level ports. Additionally, the I/O standard is set to low-voltage CMOS 1.8 V, because bank 15 is sourced with 1.8 V.
To reduce warnings in Xilinx ISE (trace) I specified that all timing paths to and from these pins should be ignored (timing ignore -> TIG
Question:
- How can I translate
TIG
into Vivado's XDC syntax?
What I discovered so far:
set_false_path
is only for internal paths andset_disable_timing
seams to be very special
