I'm working on designing a BLE device, and have settled on using a chip antenna. It seems, however, that my BLE SoC is going to have to be on the underside of the board, which might be significantly more shielded?
If that is the case, is it possible to route the antenna feed through a via in the PCB in order to have the chip antenna in a less shielded position, without adversely affecting the RF characteristics?
The PCB itself is going to be sat 4mm down in what is effectively a 15mm deep aluminium tin with no top.
