-1
I am working on level sensor which give output of 4-20 mA. I have to feed output of level sensor to an ADC of a micro-controller, to do so I have to convert it from current to voltage.Voltage range needed is 0-1.8 Volts.
So I have gone through some circuits below:
I want to know which would be much more suitable to be used with ADC of micro-controller.
Saad Rafey
  • 123
They both work but the simple resistor is less prone to inaccuracy because the op-amp will introduce voltage offset errors and possibly leakage current errors. Bandwidth of the op-amp may cause other problems if the signal is high frequency compared to the gain-bandwidth-product of the op-amp.
On the other hand, the thing that produces the 4/20 mA signal may prefer to see a short circuit as an input and the op-amp offers this by virtue of it being a virtual earth at the inverting input.
