17
I have heard this in a movie clip. I was just curious to know, is this really true?
Because the one thing that I do know, is that at a high voltage, the current decreases, so that it doesn't harm a human body.
200_success
  • 107
Pawan kumar
  • 355
  • Why is it downvoted I wonder? – sharptooth May 18 '15 at 08:09
    Downvote was probably from a fan of bad sci-fi, because the question didn't identify the movie... –  May 18 '15 at 09:33
    Current will increase proportional to voltage - at high voltage the current will **NOT** go really low at all! – Andy aka May 18 '15 at 09:37
    @Andyaka It will when the person involved eventually goes open circuit. – Roger Rowland May 18 '15 at 09:39
    @RogerRowland hehe – Andy aka May 18 '15 at 09:42
    Downvoted also because the stated information ("at high voltage the current goes really low so that it will not harm a human body") is WRONG. Never mind the rest of the question. This statement is misleading and dangerous. – JRE May 18 '15 at 10:21
    @JRE I see no problems in false statements in a question - a good answer will start with explaining why those statements are false. – sharptooth May 18 '15 at 11:26
    What does high voltage have to do with high frequency? – BlueRaja - Danny Pflughoeft May 18 '15 at 14:39
  • Its either a typo or complete confusion about the topic. I would infer confusion, hence the question. –  May 18 '15 at 14:42
  • The whole "current decrease with voltage increase" thing is for transformers. If you put a big, beefy 100R resistor across a supply of 1V, you the current is 0.01A. If you put a 100R resistor across a supply of 1000V, you put the current to 10A, but the resistor will be destroyed hilariously quick. It's just math basically. If you have y = (x/1), or I = (V/R), and you keep the denominator constant, since y and x (or I and V) are mathematically proportional, it stands to reason that increasing x or V will increase y or I. I mean, 100/10 = 10, 1000/10 = 100, 10000/10 = 1000. It's just the math. – ARMATAV May 18 '15 at 15:19
    "Because the one thing that I do know, is that at a high voltage, the current decreases, so that it doesn't harm a human body." this is wrong. – scordova88 May 18 '15 at 18:14
    @BrianDrummond which movie? – woliveirajr May 19 '15 at 17:17
  • @woliveirajr : I was hoping the OP would enlighten us... –  May 19 '15 at 19:50
  • People come here for answers and to learn.There's evidently a very wide range of ability of people posing questions from no knowledge to people with degrees in electrical/electronic engineering. If their question contains errors or inaccurate beliefs, let us correct and educate them. – Dean May 19 '15 at 23:01
6 Answers6
45
Skin Depth
The human body does have a "skin effect" but it's not as thin as you might think.
Electric currents are confined to the outside of a conducting body, but humans are not very conductive, so the fields penetrate quite deep.
The best example that comes to mind is 2.45 GHz - we all know that a microwave oven cooks about 2 or 3 cm into a piece of meat - this penetration depth is closely related to the skin depth.
The primary reason that you don't feel high frequency current is that the nerves and cells can't respond to anything above ?about? 1 kHz. I've discussed this in a previous answer, more about the safety aspects than the skin effect itself, but it might help.
Nerve effects are the primary cause of injury due to electricity, mainly the heart of course. If the frequency is high enough that it can't influence the nerves, then all you have to worry about is the heating effect. For a potentially lethal 100 V at 20 mA, only 2 W is dissipated in the body, which is insignificant compared to the 200 W of normal body heat (though it will be concentrated at the entry and exit points). So at high frequencies you can carry a much higher current than would be lethal at low frequencies, possibly without pain or injury.
High voltage and lower current
It's not true that the current is lower at high voltage. In fact, a higher voltage will usually cause a larger current to flow, than a low voltage. High voltage overhead transmission lines might be 400 kV but they also carry hundreds of amps.
When it comes to human safety, higher voltage are almost always more dangerous.
tomnexus
  • 7,617
  • 35
    Upvoting specifically to promote the debunking of the "high voltage is safer" myth in the OP's question. – mskfisher May 18 '15 at 13:47
  • Do you have a reference for your comment on the skin effect and microwaves in meat. It seems to be that the effect should be more to do with attenuation - the microwaves heating the mean means energy is being lost to vibrating water molecules. The **skin effect** is about electromagnetic induction causing currents of electrons to move to the surface of the conductor. – Tom Carpenter May 18 '15 at 13:50
    @TomCarpenter [Here is a paper](http://www.academia.edu/5351815/Numerical_Evaluation_of_Specific_Absorption_Rate_and_Skin_Depth_on_Human_Body_Tissue_Due_To_Electromagnetic_Field_Emitted_From_Mobile_Phone_Antenna) with some figures for skin depth in people. It's a bit shallower than I thought, but not too far out, 12 mm at 900 MHz, 7 mm at 2400. The heating effect is directly related to both the E field and/or the current, so is confined mainly to a skin depth or two. – tomnexus May 18 '15 at 14:11
  • @TomCarpenter He's got your reference, but those inductive fields are vibrating the water molecules, because at high frequency the 'skin effect' also means that the AC can penetrate a 'skin depth' down into the conductor. If you have a 10mm thick box, and the skin depth of your current applied to the box is 1mm, most of the current is in the 1mm thickness of the outer edge. But if you leave that box in a microwave, and you shoot waves at it that have a skin depth of 2mm, most of the current will be in the first 2mm of the box, not the first 1mm. It's the signal, not the conductor, that does it – ARMATAV May 18 '15 at 15:26
    @TomCarpenter, Skin effect *is* directly related to the attenuation that an applied wave would see due to the conductivity of the material. – The Photon May 18 '15 at 16:47
    For the second-to-last paragraph: Note that we use lower current at higher voltage when we're trying to keep the power the same. But the power doesn't *naturally* stay the same if you just increase the voltage without changing other things as well. – user253751 May 19 '15 at 00:49
  • I'm interested in the explanation for the last paragraph, "*almost* always more dangerous". Are there any occurences where higher voltage is not dangerous? Edit: I think I get the idea of electrosurgery from steveverrill's answer. – Andrew T. May 19 '15 at 04:22
  • @AndrewT there are some high voltage, low current applications, which are less dangerous than household mains. Laser printers, for example, with their 500 to 2000 V, are not nearly as scary to me as a 2 kV power line. – tomnexus May 19 '15 at 04:50
  • I take it that using a 1khz mains supply would cause enough other headaches that it's not worth the safety benefit? – Loren Pechtel May 19 '15 at 05:13
  • @LorenPechtel that is a very good point. Why don't you ask it as a new question? Apart from the shock safety, transformers and smoothing capacitors could be much smaller. Rotating machines would need a lot more poles. Core losses would go up. Skin effect would increase losses. Line charging current up 20 times. And imagine the constant hum. Aircraft use 400 Hz. Might be a lively discussion if you ask it right. – tomnexus May 19 '15 at 05:44
  • @tomnexus AFAIK "lively discussions" are very much off-topic. – user253751 May 19 '15 at 08:32
21
This isn't true.
It's perpetuated by a misunderstanding of a real phenomenon called skin effect:
Skin effect is the tendency of an alternating electric current (AC) to become distributed within a conductor such that the current density is largest near the surface of the conductor, and decreases with greater depths in the conductor. The electric current flows mainly at the "skin" of the conductor, between the outer surface and a level called the skin depth. The skin effect causes the effective resistance of the conductor to increase at higher frequencies where the skin depth is smaller, thus reducing the effective cross-section of the conductor. The skin effect is due to opposing eddy currents induced by the changing magnetic field resulting from the alternating current. At 60 Hz in copper, the skin depth is about 8.5 mm. At high frequencies the skin depth becomes much smaller. Increased AC resistance due to the skin effect can be mitigated by using specially woven litz wire. Because the interior of a large conductor carries so little of the current, tubular conductors such as pipe can be used to save weight and cost.
That is, for a uniform conductor, an increase in frequency will result in a diminished component of the current flowing through the middle of the conductor - higher concentration towards the circumference, the "skin".
Skin does not transpose to skin, be it human skin or another membrane over another conductor. If a conductor of akin to the skin's epidermis was constructed, higher frequency still wouldn't concentrate to the outer surface.
There is a field within biology called bioelectrical impedance analysis (BIA) which relies on the varying frequency response of cells and other biological matter.
Peter Mortensen
  • 1,676
This is not true, in fact it is possible to "cut" flesh with a high frequency electric current.
http://en.wikipedia.org/wiki/Electrosurgery
An alternative name is "RF knife" because (as pointed out by tomnexus) at high frequencies the electric current has no effect on the nerve cells.
One advantage of using this kind of "knife" is a lack of bleeding, because the "knife" burns through the flesh rather than actually cutting it.
From personal experience: I had a small benign tumour removed using this method. They placed a return electrode of large area on my thigh and cut the tumour from the surface of my abdomen with a small pointed tool. There was a faint whiff of burning flesh (and of course no pain during the operation due to the local anasthetic, though there was some afterwards.)
Level River St
  • 941
Datapoint: Radio Frequency, at 10's of MHz will produce "electric shock" and burns. Well covered by others the following is true despite reading like a movie makeup.
I have seen it happen in practice where somebody held the disconnected aerial lead of a transmitter while calling out that they had found why it was not transmitting. The transmitter was voice operated. It operated. There was no doubt about his having felt the shock. The transmitter was probably on either the 80 metre band (~= 3.6 MHz) or the 20 metre band (~= 14 Mhz).
Russell McMahon
  • 147,325
  • 210
  • 386
Even if the skin effect did kick in at 700 Hz for the human body, the current will then be passing through the outer layer of the body,ie. the skin. At high enough currents you are still going to cook like a sausage on a barbeque!
Not recommended to rely on the principle!!
Dean
  • 838
For definitive answers to this question look at IEEE Transactions on Biomedical Engineering or any biomed engineering journals.
    Welcome :-) Are you able to edit your post, summarise one of those articles you mention which provides the definitive answer, and add a link to it (ideally one which doesn't require IEEE membership) please? That would help to add tremendous value for readers who would otherwise be unable to find the articles you mention. Many thanks. – SamGibson Jul 02 '20 at 01:29
  • @Aussietaffy - Welcome to SE EE. A good start, but as Sam says, it would be appreciated if you could give a rererence or few. – Russell McMahon Jul 02 '20 at 08:07
