The inductor current ripple is a function of the inductor you intend to use in the application and the operating conditions. If you haven't chosen an inductance value yet, you cannot calculate this parameter.
The fundamental formula \$ v_{t} = L \frac{di}{dt} \$ applies. \$ dt \$ is the on-time of the converter and \$ v_{t} \$ is the voltage applied to the inductor. Once you know \$ L \$, it's simple algebra to find \$ di \$ which will be the inductor current ripple parameter you're looking for.
The maximum inductor current at boost mode will occur at minimum input voltage, and again is a simple calculation based on the above formula.
If you don't understand how to estimate the on-times of the converter for a given input, output and operation mode, you should spend a little time and do some research on the topology.
