What are the components, circled in red in the figure, on this transmission line ?
- 8,931
- 27
- 50
- 571
- 4
- 5
7It's there to fuel conspiracy theories ;) – Atsby May 02 '15 at 09:27
The are called aeolean vibration dampers, or Stockbridge dampers. They aren't rigid weights: the weights vibrate on the ends of the centre-clamped bars.
You can see the wavelength that they are trying to damp: it's approximately twice the distance from insulator to the damper. If the whole wire length is swinging, that's something different, and not what these dampers are designed to combat. You can also get higher frequency vibration, caused by some other vibrating thing: these dampers don't help with that either. They are just the right size and right position to damp the kind of singing you get from a wire in the wind: aeloean vibration.
Aeolean vibration causes metal fatigue in the wire. Using dampers to reduce the vibration allows you to use lighter and cheaper wire and towers. Vibration is particularly a problem with long high wires in windy locations, which is why you don't see these on the wires going into your house.
- 317
- 1
- 5
- 14
- 4,364
- 15
- 30
7My wires are buried in the ground, if there are any, thats the reason why I can not see them ;) – PlasmaHH Apr 30 '15 at 08:27
Just a random thought. How much mechanical vibration does the current in the transmission long lines create? – Password Apr 30 '15 at 08:30
3@Password: Not enough to worry about. You only get significant movement under fault conditions, when 10-100× the normal current flows for a short time. You can bend solid copper busbar that way, or tear cable ties off cables, if the mechanical restraints aren't adequate. – Li-aung Yip Apr 30 '15 at 13:53
