I am storing a 16k constant sine table of 14 bit signed vectors in a package.
I use this package in my module to read out the array in a clocked process
But I get this warning during synthesis and my synthesis is taking a long time -
The RAM will be implemented on LUTs either because you have described an asynchronous read or because of currently unsupported block RAM features. If you have described an asynchronous read, making it synchronous would allow you to take advantage of available block RAM resources, for optimized device usage and improved timings. Please refer to your documentation for coding guidelines."
code in package -
TYPE signed_array IS ARRAY (integer RANGE <>) OF signed (DATAWIDTH-1 DOWNTO 0);
CONSTANT SINE_TABLE_SIZE : integer := QUARTER_LENGTH+1; -- 16384+1
----sine pi/2 = 1 <=> "0111111....1" MSB is 0 because of the signed representation
CONSTANT SINE_TABLE : signed_array(0 TO SINE_TABLE_SIZE-1):= (
to_signed(integer((2.0**(DATAWIDTH-1)-1.0)*0.0), DATAWIDTH) ,
to_signed(integer((2.0**(DATAWIDTH-1)-1.0)*9.5873799096e-05), DATAWIDTH) ,
to_signed(integer((2.0**(DATAWIDTH-1)-1.0)*0.000191747597311), DATAWIDTH) ,
to_signed(integer((2.0**(DATAWIDTH-1)-1.0)*0.000287621393763), DATAWIDTH) ,
to_signed(integer((2.0**(DATAWIDTH-1)-1.0)*0.000383495187571), DATAWIDTH) ,
to_signed(integer((2.0**(DATAWIDTH-1)-1.0)*0.000479368977855), DATAWIDTH) ,
to_signed(integer((2.0**(DATAWIDTH-1)-1.0)*0.000575242763732), DATAWIDTH) ,
to_signed(integer((2.0**(DATAWIDTH-1)-1.0)*0.000671116544322), DATAWIDTH) ,
to_signed(integer((2.0**(DATAWIDTH-1)-1.0)*0.000766990318743), DATAWIDTH) ,
to_signed(integer((2.0**(DATAWIDTH-1)-1.0)*0.000862864086114), DATAWIDTH) ,
to_signed(integer((2.0**(DATAWIDTH-1)-1.0)*0.000958737845553), DATAWIDTH) ,
to_signed(integer((2.0**(DATAWIDTH-1)-1.0)*0.00105461159618), DATAWIDTH) ,
process(clk)
if rising_edge(clk) then
ctd <= ctr + 1;
end if;
end process;
cos <= SINE_TABLE(to_integer(unsigned(ctr)));
Any suggestions on how to write a vhdl code in infer a block RAM instead of LUTs?
The SINE TABLE is in a package, and the process is in the main module
