I made a really simple scheme/pcb using Kicad (on Ubuntu 14.04). Now I'd like to print this and make my PCB, but I can't figure out how to properly plot the damn thing!
When I plot using gerber format and open files in gerbv, everything seems to be ok (measurements/scaling is ok), but when I try to export to PNG or any other format, the scaling goes wrong. If I try to print from gerbv, I get nothing (blank page).
So, what are the proper steps to create basic front and back Cu layers that I can print and then go on with making my PCB?
I've been stuck with this for days now, so any help is appreciated...
BR, Newman
newman555p
  • 61
  • what version of kicad are you using? There are a boatload out there. The next question - you want to print something on paper - why? What will you be doing with the paper print out? Do you just want vias and traces in a layout? Is this for protoboard? Are you not getting a PCB manufactured? – KyranF Apr 23 '15 at 20:50
  • To print the pcb I just made, I export it to SVG. This way is a scalable vector. You can open the SVG file with a browser and print it from there. I never had scalling issues. – machineaddict Jun 23 '15 at 06:27
Apparently (because I'm no expert in KiCAD) the printing option is for documentation purposes, because there are some issues regarding scale and the ability of the printers to use the entire sheets (see What's the difference between printing and plotting PCB layouts, on the FAQ).
I also had problems printing (printing directly to pdf was giving bad results, the footprints were replaced by circles of different sizes, probably there are some issues with the libraries used for this purpose in my linux installation), and solved them plotting to SVG format, which can be read with inkscape, and from there exported to pdf. Maybe that path suits you.
El Diego Efe
  • 161
