Note this isn't specific to Arduino, but to any SPI master.
Drive DS1801 CLK
input from SPI master SCLK
output.
Drive DS1801 D
input from SPI Master-Out, Slave-In data (may be called MOSI
or sometimes DOUT
for data output)
The SPI Master-In, Slave-Out data MISO
does not need to be connected to anything. You can optionally drive MISO from the DS1801 COUT
output: this is the "cascade output" from the internal shift register. The data that appears on COUT is the same data that you originally wrote to D input, but delayed by 16 bits (because DS1801 uses a 16-bit shift register to receive commands from SPI.) With this connection, you can verify in software that the DS1801 device is connected -- this may be useful if it is remote from the SPI master. Otherwise don't worry about it.
Drive DS1801 ~RST
input from SPI master CS
output, but note this signal is an active-high SPI chip enable rather than the more commonly used active-low chip enable. In software, drive CS high (1) when active just before running the SPI transfer, and then drive CS low (0) when inactive. This is just the opposite of most example SPI code you will find.
Most of the Dallas Semiconductor (now Maxim Integrated) temperature sensors use this active-low Reset / active-high SPI chip select method. It's a little bit unusual, but works just fine.
The Arduino-specific stuff involves calling digitalWrite(slaveSelectPin, HIGH);
then SPI.transfer(data);
and ending with digitalWrite(slaveSelectPin, LOW);
. The Arduino comes with example SPI code, you're welcome to ask follow-up Arduino-specific questions at https://arduino.stackexchange.com/
Full Disclosure: I am an applications engineer and evaluation kits designer at Maxim Integrated; if you have further questions contact our apps team through the Support link on the Maxim Integrated website.
