Can I use this LCD display: http://www.itontec.com/product-detail/product-name-7/
With this adapter:
*Display Specs: Power Supply(5~12V 2A)
*Adapter Specs: Output: 12V - 1A
Is that safe to use this adapter with this display?
With this adapter:
Rather not. The specs of your display say that it might need 2A at times, and this would overload your adapter. This means that its voltage drops and the adapter might heat up, or break in the long run.
There's a chance those 2A spec are for the lower end of the voltage (5V) and it will pull less for 12V, but that would only be the case if you see a switching DC/DC regulator on the PCB. If it's a linear regulator, it will take 2A and just convert the extra voltage to heat.
Maybe yes, maybe no. You will have to try it and see.
Because the monitor says "5-12V 2A", there is a very good chance that the monitor has a switch-mode supply internally. That would cause the monitor to consume about 2 Amps with a 5 Vdc input (10 Watts) but consume less than 1 Amp with a 12 Vdc input (also about 10 Watts).
The only way to find out for sure is to try it.
If it doesn't work, no damage should occur to either the power supply or monitor. It just won't work.
My best guess is that it will work just fine.
