I need a logarithmic amplifier and found this equivalent schematic in the datasheet for the LOG104:
The LOG104 is rather expensive, so I want to build this myself. What are the requirements for the transistors? (I guess they have to be matched.)
I want to use this with a phototransistor to measure light levels.
Bence Kaulics
  • 6,353
  • 60
Joris Groosman
  • 969
    Look for transistor pairs on the same silicon : CA3046 comes to mind as a starting point; no doubt there are better choices. –  Apr 10 '15 at 13:18
  • The voltage generated by a photodiode is logarithmic in the light intensity. (see fig 1a here.) http://www.ti.com/lit/an/sboa035/sboa035.pdf I know that's not what you asked. – George Herold Apr 10 '15 at 13:18
  • It's a lot easier if you don't care much about DC stability. – Spehro Pefhany Apr 10 '15 at 20:04
  • I asked about this back when such questions were allowed on the site: http://electronics.stackexchange.com/questions/11263 – markrages Jul 24 '15 at 20:44
Bob Pease addressed this question in one of his inimitable "What's All This ..." articles http://electronicdesign.com/analog/whats-all-logarithmic-stuff-anyhow. See particularly figure 7.
Basically, you set up two transistors to draw the same current, and match for Vbe.
While you don't say exactly what dynamic range you're looking for, I'd guess that almost any good small-signal transistor will do.
WhatRoughBeast
  • 59,978
  • Thanks for an absolutely great link. Unfortunately at that _Electronics Design_ link the diagrams (schematics!) are no longer displayed. I was able to find a scan of the article somewhere else, pgs.18-20 of this rather large PDF http://www.introni.it/pdf/Bob%20Pease%20Lab%20Notes%20Part%204.pdf – Daniel Chisholm Sep 14 '20 at 11:29
  • @DanielChisholm - Thanks for the kind words. While I'm at it, I need to stress the need for tight thermal coupling between the transistors - they MUST be kept at the same temperature. Which is, of course, why log amps are usually made as ICs. Two transistors next to each other on a die are usually very well matched, AND their temperatures will be be almost identical. It's a lot more bother to do this with discretes. – WhatRoughBeast Sep 20 '20 at 16:30
