So I have a circuit where I need the current consumption to be low. Therefore I am using a 10M\$\Omega\$ resistor to 'pull-up' the pin on a chip which will need to be switched between high and ground (by high I mean the supply voltage which is ~3V).
In order to pull this pin down to ground when necessary I have a BJT (BC847C) which will be triggered by a microcontroller in order to bring this pin down to ground. The problem is, this doesn't seem to be working. Therefore I am wondering if there is any leakage current through the collector and emitter junction of the NPN which would be creating a voltage drop over the 10M\$\Omega\$?
The circuit really needs to be low power (in the tens of \$\mu\$A's) hence the need for large resistors as it will be on all the time (there are two switches that are being controlled by this set up and I need to switch between them)
