I got a new IR led, emitting light at 850nm. It says 5v reverse voltage and 1.5 forward voltage. How many volts should I give it? I have DESTROYED three other IR LEDs because of giving them too many volts. What should I do?!
---------------------------------ADDED----------------------------------
Here is the full information on the LED, typed up:
Max. Reverse voltage:5v
Max. Continuous forward current: 100mA
Max. Forward Voltage: 1.5 typ., 1.8V max.@50mA
So, if I give it 3.3v@50mA raw, it will destroy it, correct? Therefore, I guess I need a 10k resistor?
Bobdabiulder
  • 254
  • What kind of driving resistor are you using? What voltages did you try? – I. Wolfe Apr 06 '15 at 23:27
  • Please add the missing information to your question: what voltage do you want to run them from - and - how much current do they need? – Dwayne Reid Apr 06 '15 at 23:28
  • Possible duplicate of [Does LED brightness change with voltage?](https://electronics.stackexchange.com/questions/256336/does-led-brightness-change-with-voltage) – winny Dec 20 '17 at 06:54
As with any LED, you should be concerned with the LED current, much more than its voltage.
The voltage across any forward-biased LED (any diode, really) will be governed by the diode, and will only vary slightly with current.
Look on the LED's data sheet for the recommended operating current, or, failing that, the Maximum Recommended current. If you can only find a Maximum Recommended current, operate the LED at 80% or less of the Maximum.
You normally control the LED current using a resistor in series. The resistor value is calculated by subtracting the LED forward voltage from the supply voltage, then using the resulting voltage and desired current in Ohm's Law.
-----------------------Added, after the OP added vital data---------
With 3.3 Volt Vcc, the Atmel ATMega328's recommended output current seems to be 10 mA or so, so you can't drive the IR LED directly from an I/O pin. Instead you will have to do something like:
The 18 ohm resistor should limit the LED current to about 80 mA - safely under its maximum rating of 100 mA. 20 or 22 ohms would reduce the current a bit more, if you want to be safer.
The transistor's emitter must be connected to the Arduino ground.
Peter Bennett
  • 57,014
  • 127
  • OK, so if I run it from an Arduino Uno 3.3v output pin, what should I do? – Bobdabiulder Apr 06 '15 at 23:30
    You do what I said in my answer. Your first step will be to determine the desired operating current for your LED. – Peter Bennett Apr 06 '15 at 23:32
  • I safely powered it from my Uno using the 3.3v output pin, which, according to arduino.cc, is going at 50mA. I put one wire from the 3.3v output to my 330 ohm resistor(smallest one I have), and ran it from there. Worked fine, showed up on my phone's camera as a little purple-ish dot. – Bobdabiulder Apr 07 '15 at 11:57
  • Can you explain what equation you used and where to see their values on the transistor? I have that transistor and also a 2N2222 but I have 5V Vcc and 40mA from the arduino. – shinzou Oct 03 '17 at 19:43
  • If you put a 330 ohm resistor in series, then at 3.3v you're only drawing about 5.5ma. That's well within the limits of the Arduino output, and if it's bright enough for your purpose, very good. But if you need the full brightness of the LED, you'll need the external transistor circuit. – Carl Raymond Sep 13 '18 at 19:25
  • You need to also take into account that the transistor will also cause a voltage drop. Best thing to do is try with a resistor you estimate, and then adjust based on what you measure with a multimeter. – Alex G Jan 13 '20 at 00:46
    Hm, since you want to drive the LED at 80 mA and you want to saturate Q1, R1=1kOhm is too high. I arrive at `R1 = (2.6 V - 0.9 V) / 0.008 A = 212.5 Ohm`. Note that an ATmega328p output pin drops voltage with higher current, thus I'm using 2.6 V instead of 3.3 V (cf. datasheet). And 0.9 V is the voltage drop at the Q1 base (cf. V_BE(sat) in a 2N3903 datasheet). Assuming that Q1 saturates at `I_C / I_B = 10`, as specified in the datasheet. For R2 I arrive at `R2 = (3.3 V - 1.5 V - 0.3 V) / 0.08 = 18.7` which is what you already have in your schematic. (i.e. V_CE(sat)=0.3 V, V_F_LED=1.5 V) – maxschlepzig Feb 20 '22 at 16:15
I'm pretty sure that there are multiple answers on this site with the information that you require.
But: decide what voltage you want to run the LEDs from. Subtract 1.5V - you now know the voltage across the series resistor that you need.
Now divide that voltage by the desired current. If you divide by Amps, you get the resistor value in Ohms. If you divide by mA, you get the resistor value in Kilohms.
Dwayne Reid
  • 23,390
  • 35
  • 67
