If a person touches an exposed wire (the wire has a ground-prong) on the 20V side of a power cable while barefoot, I heard that it is possible to receive a shock of higher than 20V due to capacitive coupling. Could anyone explain how this is possible, if it's true?
minusatwelfth
  • 339
  • It is possible to receive such a shock, but it has nothing to do with the laptop, you would receive one touching anything closer to ground than you. You can develop static charges of thousands of volts from everyday activity, the 20v difference the laptop charger is making is irrlelevant, you will be shocked either way. – John Meacham Apr 04 '15 at 09:30
  • Please look at where the word 'capacitive' appears three times on this website http://ask.metafilter.com/236427/Is-my-laptop-going-to-kill-me – minusatwelfth Apr 04 '15 at 11:24
  • DOWNVOTER: The question is a good one. He is correct. Please read my answer. – Russell McMahon Apr 04 '15 at 16:25
  • @JohnMeacham If you are the downvoter on this question you may wish to consider reading my answer and amending the vote. If not, whoever the downvoter is: It's possible and usual, The question is useful. – Russell McMahon Apr 26 '15 at 00:38
Such problems are usually caused by the lack of a ground lead on the input connection with power supplies designed to need a ground connection to operate as designed.
Input ground connected: Such power supplies are required by law to have (and may or may not have in practice) "Y" line filtering capacitors from each leg of the input power lead to circuit ground. That ground may be connected to the lug you mention. Such systems are intended to have an input ground lead. If they do the two Y capacitors are connected to ground and all is well.
Input ground not connected: If the input lead OR an extension lead OR the power point used does not have a ground connection then the two Y capacitors are NOT connected to ground. The two capacitors form a capacitive divider and the centre point between them is at half mains supply.
If you touch the grounding lug in such cases then you, too, will be at half mains supply.
If you now stand on a surface that has conductivity to ground (as most surfaces do) or if you touch a grounded object you may wish that you had not.
The capacitors used are usually in the 0.001 uF to 0.01 uF range. Actual values will vary with regulatory requirements and/or manufacturer's choices. With 110 VAC mains the maximum current is well under 1 mA and designed not to be lethal for most people in most cases.
You can still feel an annoying shock (ask me how I know).
Equipment exposed to this half mains voltage may be damaged or destroyed. I once had a new printer destroy a PC printer port due to this cause.
Notes:
The actual coupling is via capacitors inside the power supply and so is independent of the state of the cable.
Any contact between any electrically conductive part of the equipment powered which is electrically connected to any part of the power supply output will be capacitively coupled at half mains potential relative to true ground.
A frayed cable that allows access to either output conductor qualifies as above.
I have experienced laptops which were (literally) shocking if used on your lap - adding an insulating layer such as a tray or even a sheet of paper helped greatly.
Russell McMahon
  • 147,325
  • 210
  • 386
  • If the cable is frayed on the 20V end, would that make it more likely that capacitive coupling occured? – minusatwelfth Apr 24 '15 at 19:29
  • The actual coupling is via capacitors inside the power supply and so is independent of the state of the cable. Any contact between any electrically conductive part of the equipment powered which is electrically connected to any part of the power supply output will be capacitively coupled at half mains potential relative to true ground. | A frayed cable that allows access to either output conductor qualifies as above. | I have experienced laptops which were (literally) shocking if used on your lap - adding an insulating layer such as a tray or even a sheet of paper helped greatly. – Russell McMahon Apr 26 '15 at 00:20
  • Answer updated ... – Russell McMahon Apr 26 '15 at 00:39
I think it's worth mentioning that pretty much any transformer-based power supply which is not grounded will have (a part of) mains voltage on its output w.r.t. ground, even without Y-capacitors. There's always some parasitic capacitance between the windings, which may not be enough to give you a shock but typically enough to produce a voltage that could be measured with a multimeter.
Dmitry Grigoryev
  • 25,576
  • 45
  • 106
