I bought a choke made of litz wire. The wire is enameled all the way to the ends. How does one go about stripping this wire?
Stephen Collings
  • 17,373
  • 92
  • 180
  • Duplicates here: http://electronics.stackexchange.com/questions/53028/how-to-remove-enamel-from-wire?rq=1 and here: http://electronics.stackexchange.com/questions/8203/whats-the-best-cheap-way-of-stripping-enamel-off-of-magnet-wire?rq=1 – Stephen Collings Apr 02 '15 at 19:17
Fire.
You can burn off a good bit of the enamel at the ends with fire. You can also use various chemicals to strip the enamel.
If the ultimate purpose is to tin the wire, use a solder pot, it's the recommended method.
Samuel
  • 11,811
  • 51
