Context
I need to analyse the performance of a system that uses inertial sensor readings as input. My knowledge of IMUs is very basic, having only read a few introductory texts.
My understanding is that IMU accuracy degrades with continuous use due to drift, which results in accumulated error.
Questions
What other operational factors (i.e. not the specific device/components, but IMUs in general) effect the accuracy of IMUs?
I have noticed in my application that the system performance degrades when the object moves, especially when the movement is fast, and then improves once the movement slows, and reaches a halt. What aspect(s) of IMUs causes this?
EDIT
To be more specific, the sensors give orientation as quaternions (rotational offset from the sensor coordinate system to a global coordinate system). The error fluctuates over time (duration of about 15 seconds), however there is not an incline in error over time. Based on this, I believe IMU drift is not an issue here.
What I am interested in understanding is why the estimate error of the object's orientation fluctuates based on the amount and speed of the object's motion.
If it helps, I am using Xsen MTx IMUs.
