Is there a way to connect a SIM module to a Gumstix? I've tried to find commercial solutions (add-on modules) that will do this but have not found any. Surely an addon providing mobile connectivity must exist?
kwo
  • 403
Depending on the gumstix module that you have, if you are using embedded linux with a board that has USB host, then you may be able to use a USB GSM modem - you stick the SIM card into it and then the module into a USB slot on a gumstix board. You would have to find drivers or write your own. A quick search finds that some people have had success using a particular model due to driver compatibility.
There are also a number of GSM modules that you can interface with using a UART channel. They are typically spoken to using an AT command set over a serial port. If you're willing to explore not having a perfectly clean modular connection (like with the gumstix expansion boards) then there are a lot of options for you.
Jon L
  • 4,258
If you mean a GSM module and SIM card, it would be easy to interface them via a serial port. This unit has everything you need on one board. I once designed my own PCB interfacing a Siemens GSM module and SIM card to a PIC controller, it was quite easy.
Leon Heller
  • 38,774
  • 60
  • 96
  • Thanks for the link, however, I'm looking for something that interfaces directly with a Gumstix providing GSM modem capability and keeping the small form factor to boot. – kwo Jun 14 '11 at 19:20
    I don't think that there is such a thing. I might design one, there is probably a market for it. – Leon Heller Jun 14 '11 at 19:26
  • Yes, I can imagine that quite a few people would be interested in something like this. – kwo Jun 15 '11 at 08:17
-1
not sure but have a look digi product instead of gumstix.
http://www.digi.com/products/wireless-wired-embedded-solutions/solutions-on-module/connectcore/connectcore3g
HTH
  • That is an independent wireless gateway product using 3G, but OP, imho is looking for a way to connect his gumstix to the net. For generic internet access he could use a regular PC as well. – bdutta74 Jan 25 '12 at 12:59
