I need some help choosing a MOSFET for the circuit that I described here, which I originally designed using a BJT but decided that FETs make more sense in this case.
The FET will be controlled by a PIC24 that sends a logic high or logic low to the FET. I know that FETs are voltage-controlled devices, but I am wondering if there is also a minimum current needed to switch the FET on?
If so, does the FET need to be biased so that the PIC24 can source enough current to turn on the FET?
I'm also not too familiar with biasing FETs, so I'm also curious about pre-internally-biased FETs but they're somewhat hard to find on Google. Could you recommend any other resources?
Christina
  • 347
A FET's gate has nearly infinite resistance, but some parasitic capacitance. What this means is that there's 0 DC current draw when on or off, but some current is required to switch between the states. Larger, higher current FETs tend to have higher parasitic capacitances, and thus require more power to turn on or off.
The current required to switch is generally very low, and unless you're switching at high speed (hundreds of kilohertz and up) or your FET is very large, you'll be able to drive it directly from your microcontroller.
The important thing to consider when choosing a FET for this purpose is not biasing, but gate threshold voltage. Make sure the selected FET's threshold voltage is low enough your microcontroller can turn it fully on. Don't rely on the figure in the datasheet table, this is often quoted for very low currents. Instead, check out the gate voltage vs source/drain current graph, and make sure that at your microcontroller's logic high voltage, the FET will be able to conduct the desired amount of current.
Nick Johnson
  • 7,739
  • 44
The circuit that you referred to is not going to work very well, regardless of whether you use a bipoalr transistor or a MOSFET. That's because you are trying to do High-Side control with a NPN or N-channel device.
Because you are working with a solar panel, you have two options: shunt regulator or series regulator.
A shunt regulator makes use of one property of solar panels: they function somewhat like a current source. That is: for a given amount of insolation (the amount of sunlight hitting the panel), the current remains roughly the same as the terminal voltage varies. A solar panel can usually run with a direct short on its' output leads without any damage.
The advantage of a shunt regulator is that the negative lead of the panel can be connected to your circuit ground and still allow the use of a NPN transistor or N-channel MOSFET to provide the short across the panel. Obviously, there is a series diode from the junction of solar panel (+) / transistor to the battery. This diode is needed anyway so that the solar panel doesn't discharge the battery when light levels are low.
Because the shunt regulator has to dissipate all the unwanted power as heat, the most common shunt regulator configuration is the "bang-bang" controller. This is where the shunt is either fully OFF (allowing maximum possible charge current) or fully ON (solar panel is shorted, resulting in NO charge current). This results in minimum heat in the switching device. Many inexpensive solar charge controllers work this way.
The other option is a series regulator. Now you have to make a choice: you can use NPN bipolar transistors or N-channel MOSFETs as the pass element BUT you have to control the negative lead of the solar panel. In other words, the positive lead of the solar panel connects directly to the battery (+) terminal (through a series diode if necessary). The negative lead of the solar panel connects to the drain of the N-channel MOSFET, with the MOSFET's source terminal going to circuit ground.
I mention that the series diode on the (+) lead of the solar panel might be optional. That's because it may not be needed because you can turn the transistor / MOSFET off when charging isn't possible because of not enough light on the panel.
If you do want to go with a N-channel MOSFET being controlled by a microcontroller, my "go-to" part for low-voltage, medium current DC switching is the IRF3708. 30V, 62A continuous, 0.012 Ohms Rds on. Drive the gate with a 47 Ohm resistor mounted as close to the gate as possible.
Dwayne Reid
  • 23,390
  • 35
  • 67
    I think it would be better to post this answer on the linked question which is about that circuit, rather than this one which is about FET gate current. – Ben Voigt Feb 13 '15 at 20:51
