I am studying for my System Modelling and Simulation exam. So the textbook says there are three categories of models.
Graphical - block diagrams and signal flow graphs.
Physical - physical similarity models and physical analogy models.
Symbolic - linguistic and mathematical models.
Putting aside my suspicion that a block diagram is no less a mathematical model than a system of differential equations, here is my question.
They define physical similarity model as a scaled down version of the original system. On the other hand, physical analogy model, is using electrical circuits to model the real system.
I thought this was last done 40 years ago, and currently nothing can beat the computational power of modern digital computers. Are analogue electrical circuits still used to model some systems?
Vorac
  • 3,091
  • 52
  • I don't think anyone is building nowadays an analog circuit to solve a set of differential equations; one instead would use something like Matlab or simulink. The operational amplifier is not that "operational" today, but I might be wrong. Interesting question. – Roger C. Feb 07 '15 at 10:46
    I have done it once, 20 years ago, at college. Since then, whom ever I told about it, responded "You have done what?" – Roland Mieslinger Feb 07 '15 at 13:55
    I liked them because it gave some 'feeling' to dynamics behind certain differential equations. You can vary parameters real time and 'see' (oscilloscope) what happens. You can simulate them numerically, but its not the same for me. A bit like tuning a radio with a digital vs. an analog dial (while walking barefoot in the snow). – copper.hat Feb 07 '15 at 16:22
  • The last big analog computer I was personally aware of was mothballed about twenty years ago and dismantled five years later. – dmckee --- ex-moderator kitten Feb 08 '15 at 00:33
  • @Roger: They're still heavily used in signal conditioning, because digital systems can only process digital data, and analog-to-digital conversion works better with analog anti-aliasing (although supersampling is also an option) and pre-amplification. And these pre-amplifiers may perform more complicated operations than simply voltage gain, for example current-to-voltage conversion, integration, subtraction, and sometimes even logarithmic response. But this is not really an attempt to implement a system model. – Ben Voigt Feb 08 '15 at 00:55
    Vacuum tubes (analog), unlike semiconductors, are not very sensitive to "high energy radiation" ... So they will still be used in some applications. – Antonio51 Oct 12 '21 at 06:44
6 Answers6
Don't forget hydraulic, pneumatic and even rolling marbles!
But seriously, I saw a great model of an aquifer made with a mesh of resistors and capacitors. You could just clip the scope to any junction to get a prediction of the water level for the next century.
These days we can solve a few thousand simultaneous equations in a few seconds or less, so this aquifer model is quite redundant.
On the other hand, we use physical models all the time in very simple circuits like low pass filters, integrators. But these are for circuit convenience, never for the investigation of a physical system. So for modelling, it's easier to just do it digitally.
tomnexus
  • 7,617
  • 35
Its still within living memory such machines were used (at least in my living memory). Below is a photo of the Phillips machine used by the Bank of England to model the economy. It went out of use in the 1970's.
(See article http://www.theguardian.com/business/2008/may/08/bankofenglandgovernor.economics )
The Phillips Machine. Photograph: Graham Turner Graham Turner/Guardian
JIm Dearden
  • 18,926
  • 30
  • 40
Smart Grid is a typical example where analog computing is still used. The analog computer can be faster for complex system tracking, but it is obviously controlled by digital systems today and seen through digital interfaces.
Another important application of analog computing is for artificial neural networks. Kohonen maps and various winner-take-all systems can be implemented on-chip using analog computing (using amplifiers and non-linear components).
MAC
  • 361
While it might be true, that computers are extremely powerful these days, you can still face applications where you have tight power constraints. There it might not be possible to use a powerful enough microcontroller or processor.
In those cases an analogue circuit might still be the way to go.
As this sounds quite vague and probably not only the asker wonders what this has to do with modelling a physical system, I'll give a short explanation what I have in mind. I can't go into too much detail but here goes:
The control system may take only 5mW of power. It is required to control a system with an update rate of 1kHz. There has to be some sort of mechanism to detect a faulty condition inside the controlled system in a very timely manner, at best in real-time (also 1kHz).
Now the control mechanism is implemented in a microcontroller which is able to handle that task quite well inside these energy boundaries. The problem was to detect the faulty condition.
For this task the analogue circuit came in. The system was modelled as an analogue circuit, and the same input was applied to the circuit as to the system. If the output differed by a to big amount, there was something wrong in the system (or the model during development stages).
Now calculating the whole model at a refresh rate of 1kHz was not possible for the microcontroller in that power budget.
Today with the advent of Cortex M4F, you might get close, they are pretty impressive, but I doubt that it is possible to squeeze it in just yet.
This might not be the modelling the asker had in mind, but it's still an application of an analogue circuit to model a physical system.
Arsenal
  • 17,464
  • 32
  • 59
  • A comment as to why my answer was downvoted would help me improve it. – Arsenal Feb 09 '15 at 17:10
  • As far as I understand my own question, it is about trying to understand a physical phenomenon e.g. by writing down differential equations. Where does design of low-power circuits come into play here? Also small uC-s can run on uA-s and sleep on nA-a - justification why analog circuit would out-calculate them is necessary. – Vorac Feb 10 '15 at 13:12
  • @Vorac I've updated my answer with an example of why this is relevant in my opinion. Maybe not in the sense you first imagined your question. – Arsenal Feb 10 '15 at 21:55
Yes - I think so. However, not as real hardware models (like in the days of analog computers) but as block diagrams consisting of amplifiers, adders, controllers, integrators, filters,...
This is a very convenient method for finding the systems transfer function and related information like bandwidth and stability properties - as a result of computer simulation (analog computing on a digital computer). For this purpose, block diagram oriented and/or symbolic simulation programs are available. More than that, such a model offers the opportunity to modify the system with the aim to improve the systems behaviour (step response, stability,...).
LvW
  • 24,857
  • 52
People don't use analogue computers much because they can't do the necessary maths that are required for analogue computer set-up and simulation, believe me there is a lot. Also many people do not have the necessary electronic skills to patch the electronic circuits.
This is very sad because I believe by not doing some semblance of analogue computing in schools/colleges/university we are not turning out enough high caliber engineers/physicists. It's very easy, but not conducive to 'real' learning to use a PC. BTW, no lecturers in my university department (control Eng), could patch a simple analogue circuit up, I was the only one!
I have a small analogue computer which I frequently use just to keep my hand in;I use it for simulating chemical processes and plant...Heat exchangers, CSTR, neural networks, etc. it's good fun! I also use breadboard to attach extra op-amps, caps & resistors also very cheap and easy to lash up analogue computing circuits.
Analog (also analogue) books are still available & cheap! Try ABE books. anybook.biz. BTW I think Russia is still experiments with them!
Chetan Bhargava
  • 4,612
  • 40
HSB
